Plug wiring route with 3.2 to 3.4 build - any insight?
I have an 86 with a 3.4/twin plug build about done and looking at plug wiring options. Was thinking, or hoping, I could use the 964 engine tin with the cut out but not sure it would fit:
http://forums.pelicanparts.com/uploa...1751402701.jpg Worst case scenario I will just cut/machine what I have but wondering if others have gone through this with a 3.2 to 3.4 build? Looked for some threads or write ups about it and came up with "not much". Thanks! Erik |
Solution use Sheridan f/g tin replacement then put the plug holes where you want them to be. |
Erik |
| All times are GMT -8. The time now is 07:10 AM. |
