fallingat120mph's Avatar
Plug wiring route with 3.2 to 3.4 build - any insight?
I have an 86 with a 3.4/twin plug build about done and looking at plug wiring options. Was thinking, or hoping, I could use the 964 engine tin with the cut out but not sure it would fit:
Worst case scenario I will just cut/machine what I have but wondering if others have gone through this with a 3.2 to 3.4 build? Looked for some threads or write ups about it and came up with "not much".
Thanks!
Erik
1986 911 Coupe
1986 911 Targa
Old 07-01-2025, 01:50 PM
Bill Verburg's Avatar
Thanks!
Erik
The 964/993 tin is problematic in a 911, the 964/993 uses a taller sealing edge that forces the engine to be mounted lower when used in a 811
Solution use Sheridan f/g tin replacement then put the plug holes where you want them to be.
Bill Verburg
Old 07-01-2025, 02:12 PM
Thanks Bill...looking into that option.
Erik
1986 911 Coupe
1986 911 Targa
Old 07-02-2025, 09:11 AM
