A buddy at work has a '78 with a bad fuel leak. He says it seems like it is this hose
![]() another view which comes out of the fuel accumulator, but this site lists that hose as only '80 and up, and assuming I had access to a parts program with exploded views it would also say it was an '80 and up part even if I was looking at a diagram for a '78. Does anyone know what the deal with this line is?? Thanks,
Senior Member
Can't tell for sure but I think I had a fuel leak with the same hose. Do a search on my user name for some pictures. I recrimped the hose and the leak has stopped and has not returned. Scary place for a leak though as it dumps fuel onto the engine tin right above the heat exchangers and next to the spark plugs.
Here is the thread HELP.... Have a fuel leak, how do I fix it
78 Euro 911sc Targa 03 Hayden SCWDP Last edited by osidak; 07-08-2003 at 08:10 AM.. |
Thanks, I think you are in the right spot. That's why I love this board.
I had the seame problem on my '77. The fuel line into the accumulator sprung several pinholes leaks.
I tried to buy the replacement line from our host but there was a mix up and so I got if from my local Porsche dealer, about $60. Changing it is a real opportunity to get to know your car. (Thanks to John Walker for his help.) You have to support the engine & tranny, take off the sway bar and transmission mounts. Then you can get to the connection. I believe the supply line is on the passengers side of the car. Watch out for gas running out of the tank. For my saga do a search for Major fuel leak Frank |
