-   -   OEM Floating rotor T-locks don't fit (http://forums.pelicanparts.com/porsche-911-technical-forum/117976-oem-floating-rotor-t-locks-dont-fit.html)
don911 07-07-2003 06:26 PM
For my 930 brake upgrade, I'm putting on 78-80 OEM front floating rotors. I got new T-locks from VCI. Now the problem.... The T-locks fit great on one rotor but on the other, the T-locks are too big. Looks like the slots on the factory rotors are not all the same. How can this be?? Where is the quality control at Porsche? :D
Anyway, I did a search and found a post where someone had the same issue. Sounds like filing down the T-locks is the answer. Do I need to worry about filing too much and getting too much slop?
Also, any suggestions on torque for the t-lock nuts?
Thanks,
dean 07-07-2003 07:33 PM
I don't think it is a problem. I had to file the rotors a little also.
don911 07-07-2003 08:27 PM
Thanks Dean. I should have tried filing before I posted. I filed the flat part of the T-locks. It didn't take much more than taking off the finish before they fit.
