911SC '82
Can you help identify my WUR?
Hello
can you help me identify my WUR, the exact bosch code or pet book code?
my car is an US version 911SC 1982 coupe 3.0 (w/whale tale , o2 sensor)
these are the images
https://i.imgur.com/zGIgu6a.jpeg
https://i.imgur.com/ENensLV.jpeg
https://i.imgur.com/pbiux88.jpeg
https://i.imgur.com/aSKZP7i.jpeg
if i see correctly my WUR doesn't have the lateral vacuum lines, only on on top.
is this the model i need?
https://www.pelicanparts.com/More_Info/911606105KX.htm?pn=911-606-105-KX-OEM
i'm asking because i would love hunting for better prices and i saw a lot on ebay and elsewhere cheaper so before spending a grand on this i want do a quick more research
thanks
Old 06-07-2025, 08:14 AM
Crotchety Old Bastard
RarlyL8's Avatar
What year/engine?
We handle rebuilds on WURs and fuel distributors for all 911 CIS model variants 1973.5 to 1994.
Old 06-07-2025, 09:00 AM
Wur
There should be a number on the top. I would bet yours is a 090. Fuel Injection corp, they're in California rebuilds these. Or def talk with Rarly8.
Old 06-07-2025, 11:11 AM
AndrewCologne's Avatar
Originally Posted by francesconyc View Post
Hello
thanks
Your engine (930.16) does not need a WUR with vacuum lines. Only one vent/atmosphere hose connector on the top.
Check here in the article further below where its mentioned which one is the correct WUR for your engine:
https://nineelevenheaven.wordpress.com/the-911-sc-3-0-engine-with-catalyst-and-lambda-control/
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control
All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models:
https://nineelevenheaven.wordpress.com/english/
Old 06-08-2025, 04:51 AM
911SC '82
thanks!
Old 06-27-2025, 10:24 AM
911SC '82
Originally Posted by RarlyL8 View Post
What year/engine?
930.16 is the engine
do you also sell in exchange of core? since im not going to replace it myself i need to buy it, and give it to my mechanic, also to avoid having the car parked in their lot for weeks...
Old 06-27-2025, 10:27 AM
911SC '82
i;ll try again, it's super dirty and i need a brish probably to discover the number
Old 06-27-2025, 10:28 AM
Still here
pmax's Avatar
Hello
thanks
4th pic ... Move that dang hose, what is it anyway ... doesn't look OEM to me, out of the way and take a pic.
090 if it's OEM is somewhere here.
Old 06-27-2025, 10:49 AM
RarlyL8's Avatar
We stock all varieties of 911 fuel distributors and warm up regulators. Turn around time is typically one day from receipt of your rebuildable core.
Old 06-28-2025, 08:51 AM
911SC '82
it's impossible for me to see the number, beside the hose connected the surface seems all corroded or whatnot, so even if i could take a pic of that side it woudl be impossible
is it possible to buy thw WUR withouth the core shiptment first as i sadi i have no time for it now
Old 06-29-2025, 08:54 PM
PCA Member since 1988
Contact Tony. boyt911sc. He will end you a tested good WUR
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 06-30-2025, 12:22 AM
Sent You a PM……….
Francesco,
I sent you a PM last week offering you a WUR-090 loaner that you could test in your car without any obligation to purchase. I had sent you several PM’s before and you just ignored them. So you are not interested. Good luck with your search.
Tony
Old 06-30-2025, 08:30 AM
Still here
pmax's Avatar
In that case, I would go with the 090. That should be fine.
Old 06-30-2025, 10:37 AM
911SC '82
Originally Posted by boyt911sc View Post
Francesco,
Tony
hi, sorry for the delay, super busy with work and not usiing my car, yes im interested i sent you a PM thanks
Old 07-04-2025, 09:25 AM
911SC '82
thanks good call, is seems the overall consesus also reading other posts thanks!
