freesaints's Avatar
G-Body Numeric Racing shifter
Just saw a recent post on Rennlist from Numeric Racing announcing their new shifter ine for G-body cars (901, 915 and 930). I know they're big in the newer model Porsche community but any thoughts on how well they'll work in air-cooled cars? I'm also curious if anyone has any speculations around how they'd compare to a Wevo w/components. Comparable? Significantly better? No improvement at all?
https://rennlist.com/forums/911-forum/1240549-new-numeric-racing-shifter.html
1987 Porsche 930 - Grand Prix white
1998 Acura NSX - Kaiser silver
1976 Jeep CJ5 - Sunshine yellow
Old 03-12-2021, 05:55 AM
Flojo's Avatar
it's on preorder status.
how is someone supposed to give user feedback or comparing experience?
from the looks: it doesn't kick me of my feet and from the money it will not make me remove my WEVO.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 03-12-2021, 06:09 AM
freesaints's Avatar
Was looking to see if someone had experience with them as a brand, not necessarily for their experience with the g-body shifter. Typically brands will be consistent amongst products so was looking for any "speculations" on how this will be. All conjecture at this point but I thought it was an interesting conversation to be had.
Old 03-12-2021, 06:29 AM
356RS's Avatar
I just installed the Numeric Racing shifter with cables in my 2019 T yesterday. The manufacturing and engineering of the shifter is precise, excellent work. If you just buy the shifter it will be an easy install. The cables....not so easy.
Mark Jung
Bend, OR
MFI Werks.com
Old 03-14-2021, 07:43 AM
82 911 SC - Ancora Imparo
I've heard great things about Numeric and they are local to me, so there are plenty of folks using their stuff in later model cars. This shifter looks very similar to the WEVO version. I've got the WEVO shifter and linkage, while the Numeric version includes both of those as a package. But the overall pricing is very similar too. Supplies were limited when I purchased my WEVO stuff, so I suppose I would have considered Numeric if I couldn't get WEVO or if I wanted to support a local business.
Ethan
1982 911 SC - Wine Red Metallic Coupe
Old 03-14-2021, 08:49 AM
Harpo's Avatar
Numeric racing shifter
Looks cool and ball bearing precision sounds cool
Old 03-14-2021, 12:47 PM
freesaints's Avatar
I think the main question that I'd have of Numeric is how they feel their shifter and linkage compares to the Wevo with PSJ and billet clamp. As someone asked on Rennlist "High-precision shifting system components are already available on the secondary market that seem functionally comparable. So, the key question is specifically how is the Numeric Racing shifter itself superior to the WEVO racing shifter, for example?"
Hopefully Numeric will respond to my question.
Old 03-15-2021, 07:36 AM
Harpo's Avatar
The WEVO uses no bearings or bushings. I have upgraded my wevo with bushings. Real bearings would be very tight and precise. Weather or not this is necessary is up for debate
Old 03-15-2021, 07:40 AM
freesaints's Avatar
For those interested, this was their response to my question about the Wevo comparison:
"This comes down to the mechanics of the shifter. In short, if you take a look at the Wevo for example, the pivot points use similar mechanics as the stock shifter (a tightened down pin on both axes). Ours offers ball bearings on both the axes, which eliminates any slop and also no play will occur over time either. Our shifter is referred to as the equivalent as your hand reaching into the transmission and shifting the gears directly."
They will also have a shift lever that looks like the stock shift lever to begin with. The kit includes the Numeric Racing Shifter, Numeric Racing maintenance free shift linkage, Porsche replacement shift rod bushing and Porsche replacement shift lever ball socket (Part #: 91142413900)
Old 03-15-2021, 10:01 AM
KTL KTL is online now
Schleprock
KTL's Avatar
"Our shifter is referred to as the equivalent as your hand reaching into the transmission and shifting the gears directly."
I had to laugh at this statement simply because of the literal-ness.
Speaking from personal experience in shifting a 915 during (dis)assembly, it's a real pain in the arse to select gears by hand without the advantage of the actual shifter or a even a T-handle attached to the main shift rod.
So i'm pretty sure I don't want one of these Numeric Racing shifters......
Kevin L
'86 Carrera "Larry"
Old 03-15-2021, 11:37 AM
Mahler9th's Avatar
Now that is funny KTL!
I have had similar experiences when working on my 915s, lol.
I am a relatively early adopter with the WEVO shifter and PSJ (since 2002). I was able to witness their development process at various points and consider the principals at WEVO friends. The WEVO designer has pro racing technical experience in arenas like IMSA and Grandam.
Mike
PCA Golden Gate Region
Porsche Racing Club #4
BMWCCA
NASA
Old 03-16-2021, 10:06 AM
Harpo's Avatar
I'm seriously considering selling my wevo and buying this
Old 03-18-2021, 07:10 AM
I'm with you on this.
Old 03-18-2021, 07:35 AM
kinein's Avatar
Send a message via Yahoo to kinein
When do pre-orders start?
Old 03-18-2021, 07:47 PM
Registered Minimalist
75 911s's Avatar
Tomorrow. but it doesn't look like it has a reverse lock-out...
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 03-18-2021, 08:05 PM
How much?
Old 03-18-2021, 08:37 PM
Jeff Alton's Avatar
We use and sell plenty of Numeric products, shifter and cables. Interested in trying one of these.
www.turn3autosport.com
Old 03-18-2021, 08:54 PM
The new pedals from Numeric look pretty good too.
Ethan
Old 03-18-2021, 08:58 PM
75 911s's Avatar
Numeric responded to my inquiry about reverse lockout, it is there, just hidden down below. The pedals look great AND you can order sans logo! :-)
Old 03-19-2021, 07:34 AM
I'm interested in how the 901 version works as well, currently I have a Rennshifter for the 2.0 914 and a Wevo for the 914-6GT clone.
And a Hargett for the 81SC and Wevo for the 78SC.
Old 03-19-2021, 08:21 AM
