ischmitz's Avatar
Send a message via Skype™ to ischmitz
Rear sway bar installation - help needed
I got myself a type II rear sway bar with the ends having the hole to attach to the drop link. I also got the Type II droplinks that bolt to the sway bar and to the rear trailing arm. Unfortunately, my car has the earlier trailing arms with the ball point mounts in place.
What do I need to attach this sway bar to early control arms with ball mounting points? Any ideas or kits out there?
I have seen one article from Steve Grosekemper where he makes some bushings that mount to the sway bar and use the earlier drop links. Is that the way to go? Are there any other kits out there?
Where do I get the clamps that have to be welded to the chasis to mount the sway bar?
Thanks,
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 07-11-2003, 01:29 PM
DByers's Avatar
So let me get this straight, you can do an engine pull and install a 3.6 into your 74, get all the bugs worked out and be driving it in less then 48 hours with little to no sleep but you cant put your rear sway bar on?
Hey shouldnt you be working anyways.
Hey dont forget to fill out that Gruppe B application and send it to #001.
And no I cant help you with the rear sway bar problem. Wish I could though.
Dan Byers
Old 07-11-2003, 02:09 PM
