OsoMoore's Avatar
Is this a sufficient Flywheel Lock?
I don't have the special tools for locking the flywheel, but I did have this steel "loop" from the generic engine mounting yoke. I looped it over one of the bolts to the case and a bolt into the flywheel.
Might this break a bolt off, or damage the case or flywheel?
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery.
Old 07-09-2025, 07:53 AM
They are only 66lb, so no problem. The yolk is on the wrong side for disassembly.
206 637 4071
Old 07-09-2025, 08:24 AM
OsoMoore's Avatar
Thanks for the confirmation on the locking setup.
I ended up putting the yoke on the wrong side because I couldn't fit it onto the correct side while mounting the engine - the exhaust was rusted to the heat exchangers blocking access, and I couldn't get them off until I could flip the engine over on the yoke. So one of my next steps is going to be to flip the yoke. I'm working solo, but I think I can put a wood cradle on my motorcycle lift to hold it while I turn the yoke.
Old 07-09-2025, 08:26 AM
I think I might have used a double closed ended wrench to hold mine to the case bolt.
Rutager West
Old 07-09-2025, 09:26 AM
I've posted this a few times, but it is such a no brainer, everyone should see it. Just change orientation for loosening or tightening.
Old 07-10-2025, 08:49 AM
Your engine comes with a little bracket that serves double duty for this purpose. ;-)
https://www.pelicanparts.com/More_Info/90110115100.htm?pn=901-101-151-00-OEM&srsltid=AfmBOorHUhR--mANjeKmsW1hoE37TpqpJeH3uWYvF5eOdBX_ZER-yHBd
Old 07-10-2025, 10:20 AM
Originally Posted by Locker537 View Post
HaHa, even better, if your engine still has it.
Old 07-11-2025, 08:48 AM
OsoMoore's Avatar
Pro tip - don't do it how I did. Now I have a little bend in the last inch of the stud. Use the wrench method or something that lines up closer, and don't tighten it down with a bolt on the outside.
Hopefully the little bend isn't an issue.
Old 07-11-2025, 09:31 AM
