nicfranc's Avatar
Valve Cover and Crossover Pipe Conflict 1980sc
I don't know why but my crossover pipe prevents me from removing my left side valve cover.
Did the pipe warp ?
Only way to remove it is to remove the studs as well as the nuts that hold down the valve cover. Is this common ?
Thanks in advance.
1980 911sc Petrol Blue Metallic Targa, 300,000 + miles
M&K Pre Muffler + M&K 1 in & 1 out Sport Muffler
Previously owned and rebuilt:
60's VW Bugs, Buses & Ghias
Old 05-17-2013, 08:01 PM
nicfranc's Avatar
This must of warped out of position from the heat
Old 05-17-2013, 08:23 PM
SchnellSchweitz's Avatar
This is Abbie Normal.
Could be warped, but also could be assembled wrong. Check to see if the pipe can be removed, rotated and reattached or there is a gap at the connection on the other end that would cause it to appear bent.
Let us know what you find.
'82 SC 3.0L Targa, Chiffon/Brown
“It all began when I was looking around but couldn’t find the car of my dreams anywhere. So I decided to build it myself.” - Ferry Porsche
Old 05-17-2013, 09:09 PM
ROW '78 911 Targa
timmy2's Avatar
Apparently it is time for SSI's and backdated heat, no problem with a crossover pipe again!
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-17-2013, 09:17 PM
nicfranc's Avatar
I wish….
Not in the budget this year but I do like my M&K pre muffler and sport muffler.
Great sound and a little boost in the zoom department.
Old 05-17-2013, 09:29 PM
nicfranc's Avatar
Yea that's what I thought. Abbie Normal. (Love Young Frankenstein)
I did have an exhaust leak where the cat met the cross over pipe…...maybe that had something to do with it.
Thanks for checking in.
Old 05-17-2013, 09:39 PM
nicfranc's Avatar
How I solved the problem…..
My exhaust leak at the cat crossover pipe caused the crossover pipe to warp and it trapped the valve cover closed on the left side or drivers side.
So i removed the pre muffler and stuck a pipe into the crossover pipe and gently bent it back so it no longer was up against the valve cover.
Had me scratching my head there for awhile but when in doubt a Big Pipe or Hammer in small doses gets the job done.
Now I will go crawl back under the car for the rest of the weekend.
Old 05-18-2013, 03:37 PM
Glad to hear you got it. Those pipes are a b#tch to get hooked up right. Bet those bolts will loosen up once they get hot. Make sure to check after your first few drives. That will help provide a tighter fit.
Old 05-18-2013, 04:28 PM
Guardsred911's Avatar
Had the same issue with my 80SC.... Ended up just dropping the headers to solve.... But the pipe to bend it as a solution is a great one...
J
911 SC - 1980
911 S - 1977
Old 05-23-2013, 06:43 PM
can a one piece crossover pipe be pulled out and replaced after removing all the attached nuts? I have a 84 911 Carrera.
Old 07-14-2025, 05:57 PM
