'73 911 T Targa
Fumoto vs Stahlbus drain valve
After reading a recent oil change thread about people covered in hot oil, I’m thinking about a quick change valve.
The Fumoto looks very robust and seems to positive locking valve, but if the valve were ever compromised, there’s nothing to stop the oil from escaping. The Stahlbus seems lighter, but has a cap, so if the valve were to fail, at least the cap provides some backup. Any thoughts on this? |
Ohhhh i do like that.. i think i will get one for other vehicle..thanks for sharing
If it adds weight to the car, it's not going happen for me.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
Reiver
There is a safety clip on the valve and where our oil tank sits you'd have to be rock crawling for something to get up to that height. I had one on my Lotus Elise and have had this one on my 911SC for about 5 years now. You'd have to take the bottom of your motor off before something could engage it.
De Oppresso Liber Strength and Honor 5th Legion |
I have had the Fumoto valve on my 3.2 oil tank for close to 4 years now, and on two of my other cars for close to 8 years. Unless something traumatic happens, you're not going to have a problem.
It's a 914 ...
How much time does one of these devices save you? Somehow it seems like a low risk/reward ratio.
Reiver
Straight steady stream of controlled oil exits, if you have a proper container no splash. The oil stream is less than that of removing the bolt and more manageable....and when removing the bolt there is always a splash issue initially. Just makes a messy job less of a mess.
De Oppresso Liber Strength and Honor 5th Legion Last edited by Reiver; 12-29-2020 at 09:34 AM.. |
1979 911 SC
After looking at both of them I opted for the Stahlbus. It seems much lower profile that the Fumoto and the valve is internal and looked less likely to be opened accidentally. It comes in two pieces. The plug with the internal valve and the second piece attaches to the plug with a section of hose for your pan. The valve only opens when the second piece is inserted and twisted. The down side being that you better not lose the second piece/hose combo or the thing is worthless.
I'll be installing it after I perform the first oil change either this weekend or next. I'll let you know how it goes. |
The biggest thing is to be able to stick a rubber hose on the end, and guide the oil flow right into a 5 gallon container with ZERO splashing of oil from the torrent that comes out from the plug removal. It does save time, but most important to me, is no oil cleanup on the floor form the splashing of hot oil.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Racer
I now use a suction device to remove oil from my oil tank instead of removing the drain plug.
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Reiver
I use to do that...time consuming and a pita....and you still need to drain the block anyways.
I use the Eaton (Aeroquip) quick drain valve. Can't drain the oil with out the mating part that has a barbed fitting for a hose. Very low profile and very happy with it
From a grumpy old guy:
In the 20 years I have done oil changes on my 911 (and all the ones over my lifetime), I have never felt the need to one of these. At about $30 each, I fail to see why I should not keep my $60 in my pocket for other things. Exercise a bit of care and the factory plugs work fine. Plus as these are valves, it is another potential (albeit very small) failure point. I like to minimize points of failure.
Reiver
The conversation is never over until a grump old guy complains about 30 bucks.....on a Porsche.
Racer
For me, the pita is draining the oil tank into a large pan. The engine does not need such a large pan. With the race car and the front oil tank with 3 gallons of oil in it, I want avoid the pan method at all costs. The MightVac fluid vacuum tank is much easier....for me.
Reiver
ways/Skin/Cat
Racer
Dude, how many times do I have to say “for me”??
'73 911 T Targa
I'm intrigued. Is this for the oil tank or for the sump? Which part did you get, and is there a specific model number?
Paul 1987 Carrera coupe |
