jungspike's Avatar
Brake Part Recommendations
I planning on removing-and-replacing the majority of my 1984’s brake parts... and I am requesting recommendations for which brands of parts to buy. My car is mostly used on the street and occasionally autocrossed. I plan on replacing the master cylinder, calipers, pads and rotors (as a minimum). There is nothing major wrong with the current system, but since I have the original master cylinder and 3 out of 4 calipers, I figure they are due for replacement. My car has about 119,00 miles. I plan on buying the Uro master cylinder and PBM Performance rebuild calipers from our host. I have no idea which brake pads or rotors to buy. Any suggestions? Also, any other brake parts I should get while I am in there? I have recently replaced the rubber brake lines. I have also recently rebuilt my pedal cluster which helped with brake pedal slop. Do I replace the front wheel bearings?
Thanks in advance,
Tim
84 911 Targa 3.4L
Old 07-20-2025, 08:07 PM
Bill Douglas's Avatar
I'd be inclined to just fit some new brake pads to your existing setup and see how that goes. Porterfield R4-S have rave reviews.
Old 07-20-2025, 10:04 PM
If there's nothing wrong with your calipers and master cylinder, there's no need to replace them.
replace the fluid and put some good pads on it. I'm one of the many who is a fan of the R4-S. Check the front wheel bearings for play and grease. They're adjustable, and you can easily tighten them if needed.
'80 SC Targa
Avondale, Chicago, IL
Old 07-21-2025, 11:25 AM
PCA Member since 1988
^^ This. "If it ain't broke, don't fix it!"
Otherwise you will be back here to share your frustration about bleeding the brakes.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 07-21-2025, 01:14 PM
jungspike's Avatar
LoL--OK thanks. I have many other projects to spend money on.
I'll get some R4-S and move on.
I frequently change brake fluid and check wheel bearings.
Case closed.
84 911 Targa 3.4L
Old 07-21-2025, 07:27 PM
Brake pads are an interesting decision. Too far to the Race Grade Pads direction, you get noisy street service. Race hard on a street pad you get brake fade. You can throw a bunch of money at it, like I typically do with most everything I do (like a curse). But that’s just me. I ended upgrading my ‘83 SC with Cayman four piston calipers and ‘84 and up rotors. I really like the setup, but do I need it? Nooooo
Old 07-21-2025, 08:35 PM
Danimal16's Avatar
I would offer that you do two other inspections.
Brake Disk thickness, replace if out of spec.
Inspect brake flex lines.
Dan
Old 07-21-2025, 08:49 PM
jungspike's Avatar
Thanks Danimal16.... I'll do that.
84 911 Targa 3.4L
Old 07-22-2025, 05:51 AM
