New User
Fuel pump differences CIS
Well after my minor fuse box fire I will need to replace the fuel pump on my 82 SC.
My brother has a new pump for a 77 911 he is willing to donate.
Will this work?
Old 07-27-2025, 02:39 PM
Fuel Pump Capacity…..
Will this work?
The SC’s 3.0 liter motor CIS will need a FP with the capacity to deliver 1 liter per 30 sec. (Minimum) or 2 liters per minute (minimum).
Tony
Old 07-27-2025, 08:55 PM
The connections at the pump are different sizes and don’t interface simply.
Bruce
Old 07-28-2025, 04:21 AM
PCA Member since 1988
It "should" work, however, as Bruce noted, the hose connections probably are different and will require adaptors. Len is your friend if you decide to adapt it.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 07-28-2025, 03:38 PM
