930 fuel injector compatibility
Does anyone know if the 3.3 930 fuel injectors (Bosch part number 0437502017) will work in a 3.0 930 (Bosch part number 0437502009)? Thanks!
Crotchety Old Bastard
The -017 part number is for the 86-89 USA 930, the -009 part number is for the Euro 930. Either will mate up with the 3.0L fuel lines.
The -009 injector has a bit more capacity than the -017 but this is not needed unless the engine is heavily modified. If your engine output is under 400whp either will work.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 Last edited by RarlyL8; 07-28-2025 at 06:31 AM.. |
Thanks very much, really appreciate your help!
lake wales fla
The 017 has a significantly higher opening pressure than the 009. On my injector tester I usually see at least a 10-12 psi difference in their opening pressure’s and sometimes more.
Richard |
