Anyone Use the JWest G50 Coupler?
Does it improve shifting?
Does it transmit more noise into the cabin? https://www.jwestengineering.com/G50-Coupler_p_25.html ![]()
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus |
Call 911
I installed the JWest coupler on my '88 and found that it improved shifts by a more positive "feel". There was no rattling or buzzing noises - no change from the stock coupler in this respect.
![]() ![]() Shortly thereafter, I installed the JWest shifter which I highly recommend. ![]()
Dave Kirk My Porsche restoreth my soul. |
Thanks, Dave! That's what I was hoping for!
Still here
Similar thread pops up regularly and the replies, down to the pictures, are similar or identical every time.
https://forums.pelicanparts.com/porsche-911-technical-forum/1179994-modern-opinions-shifter-upgrades.html |
I have the wevo shifter and PSJ. Love it. Increased noise is there but minimal.
Hopefully it's at least worth reading. |
What is PSJ?
Still here
What happened with the Shift Coupler Whisperer ?
![]() It is the next step in the evolution of the coupler. It replaces the rubber solid portion and the arm behind it with a classic pin and block joint. I think it's a night and day difference between the rubber solid coupler, but others may disagree. I read when I bought my car that the '87s are the noisiest of the G50 rattlers. My car has the insulated shift rod but still rattles under load in 3rd or 4th. It rattles about the same with the PSJ as when I got the car. I've heard 915's rattle worse. If you can spring another couple hundy, I think it's worth it.
Incidentally, I found it rather difficult to get the stock coupler back onto the gearbox input shaft. It didn't just slide on easily, and was impossible to get on from under the car. I had to go into the tunnel and push the coupler back towards the gearbox as hard as I could, which caused the gearbox to move from 4th to neutral to 3rd. Then I'd pull the coupler forward, rinsing and repeating multiple times until the coupler walked far enough onto the input shaft to thread the screw through.
The install is a royal *****. Getting that boot over is a ***** too. All in all, not a fun one
![]() The PSJ is easier to install than the G50 beefy coupler.
Welp, I just pulled the trigger on the PSJ
![]() Ordered directly from Wevo - it's $84 cheaper than our host!!! That will decrease slightly when they include the shipping charge but still...
Let us know what you think when you get it in there! Congrats man.
Interestingly, I've never had the tunnel cover off when shifting until now. Check out this vid of the coupler while moving the gear shifter slightly in the 3/4 plane. You can see there is slop in the fore/aft plane at the rubber coupler. I expect either the JWest coupler or the PSJ would help this...
https://youtube.com/shorts/csS5EfmQ9JE
1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus Last edited by wrxnofx; 08-05-2025 at 02:41 PM.. |
That looks normal to me. I thought the bolts were shoulder bolts and prevented the disc from being clamped up on. It's essentially a 'rag' joint similar to steering couplings of yore. It has some fwd/aft give to be more forgiving on the dogs, etc.
Now I'm staring a dkirk's post with all 4 bolts in. Is this what J-west wants? OE is only two bolts I thought. Seems like adding the new bolts prevents the forward/aft expansion the rubber allows. Huh... EDIT: Just read the J-west instructions and that is correct per their documentation.
Hopefully it's at least worth reading. Last edited by AlBackus36; 08-06-2025 at 05:17 AM.. |
Yeah, the OE rubber is held at the top and bottom with rivets. So if you go with the JWest coupler you have to drill out the rivets and use the supplied bolts instead.
