-   -   Anyone running Duracool (R12a)? (http://forums.pelicanparts.com/porsche-911-technical-forum/118130-anyone-running-duracool-r12a.html)
nhromyak 07-08-2003 04:30 PM
Anyone put this stuff in there car?
Results?
Pressures... etc?
TIA
david914 07-08-2003 04:41 PM
Not yet... Just ordered 5 cans and a can tap on Monday. I've got some blower fan maintenance to do first (this weekend, hopefully) then I'll charge her up. Talked with Don at Duracool USA for quite a while before ordering. Real nice guy, and knowledgeable. Raised my comfort level considerably. I'll post some results when done, although this is going to be just a "top off" of the system. No replacing hoses, extra condensers, etc. That'll come later (after I get a garage!). I'm just trying to get through another HOT Richmond, Virginia summer without sweating to death in commuter traffic!
ChrisBennet 07-08-2003 04:50 PM
US EPA Legal status of HC-12a®, DURACOOL 12a®, and OZ-12®
Tim Polzin 07-09-2003 07:45 AM
Interesting information Chris. According to this information, as long as your not in the 18 States that outright ban HC-12a, AND the car has previously been converted to HFC-134a, you can legally use HC's in your car.
Tim
Jim Sims 07-09-2003 08:23 AM
I wonder how a sham conversion to R-134a is defined? Not running a minimum amount of time with R-134a? Not changing over to PAG or Ester oil? Not having the proper fittings, pressure limiting switch and conversion label installed? After all that was done, would it be worth going to Duracool? It seems the appeal of Duracool is the simplicity and to say money; those are lost if one follows the regulations and makes a real conversion first. Jim
911pcars 07-09-2003 10:29 AM
The way A/C repair shops are currently set up, they probably couldn't (won't) touch a car that contains anything other than R-12 or HC134a due to contamination with their testing, evacuation, recycling machines and recycled refrigerant tanks.
Thus, you're left to find a shop that'll perform these steps (maybe the place that sells Duracool or equiv.) or purchase your own refrigerant-compatible service equipment and DIY.
Sherwood Lee
http://members.rennlist.org/911pcars
BGCarrera32 07-09-2003 11:02 AM
refrigerant-compatible service equipment...
1) atmosphere
2) appropriately sized wrench
System now ready for vacuum pump and recharge...;)
turbo6bar 07-09-2003 12:48 PM
From what I've read, the propane/butane mixes are used in thousands, if not millions, of A/C and refrigeration systems worldwide. You can buy refrigerators that use the blend, but not in the states, I believe. The specs for Duracool and other blends surpasses R-134a, even with regards to safety. So I really wonder why we are still using freon???
I do agree the biggest complaint against Duracool is the fact you resort to DIY.
Jurgen
nhromyak 07-09-2003 01:45 PM
Thanks for everyone's replies.
My biggest reason for trying this stuff is not changing the oil or the drier/accumulator. We don't have to change the non-barrier hoses as R12a will not "leak" through these hoses.
BTW: If your A/C mechanic KNOWS your hoses are non-barrier hoses - BY LAW - the A/C mechanic must CHANGE the hoses to the BARRIER type no matter the refrigerant used.
I was hoping to find someone who is already using this in a 911 successfully.
6 oz of R12a = 17 oz of R12
Hence, my 39 oz system will only use ~ 2 1/2 cans of R12a.
David - My system only uses 39 oz. That's 2 1/2 cans total after an evacuation. My problem is getting it evacuated. :(
CHRIS - Basically it's illegal in ANY motor vehicle. Yet it can be used in a motor vehicle if it previously had R-134a. Gotta' love the government!
JIM - I read where a R134a conversion using proper fittings, pressure limiting switch and conversion label installed is adequate. :)
The largest appeal to me for using R12a is how (the manufacturer claims) it will NOT "leak" past non-barrier hoses!!!
:cool:
911pcars - You are correct. Everyshop I talked to said they won't do an evacuation on my car, as I tried adding a little R12a.
BGCarrera - ;) I just need an vacuum pump.
Turbo - Yep R134a is also FLAMMABLE/combustable. BUT R134a went through the rigourous testing that the EPA required for it to meet the Freon replacement category where as R12a did not. I forget where I found that at.
Jim Sims 07-09-2003 02:02 PM
If one wants an R-12 compressor to "live" very long with R-134a the oil must be changed to PAG or ester type. Also, the receiver/drier likely will need to be changed as there is a compatibilty problem (right off I can't recall if it's the oil or R-134a) with the older type of dessicant. Jim
turbo6bar 07-09-2003 04:11 PM
rigorous testing + EPA = oxymoron
incompetent + EPA = the truth
my limited experience with the EPA and the government tends to support those equations.
emcon5 07-09-2003 05:09 PM
From the EPA web site, "Unacceptable Substitutes":
Flammable blend of hydrocarbons; insufficient data to demonstrate safety
Personally I am less concerned with 15 oz of a flamable gas spread through 30-odd feet of hoses throughout my car, than the gasoline pumping at 65 to 75 psi.
Not very.
Tom
Steve W 07-09-2003 05:57 PM
I don't run DuraCool but I am running basically the same thing in my Toyota truck. I made the cocktail myself with a $2 bottle of torch propane and a $4 can of isobutane camping fuel from a sporting goods store. It's worked well and my system blows ice cubes. I am not really concerned about the flammability of the gas, as a 36 oz R12 system only requires a 14 oz of the mix. If the system was ruptured, such as in an accident, the gas/liquid would just whoosh out so fast and vaporize, that it would not have much time to do any damage. I'd be more concerned about the 75 lbs of gasoline running through your fuel system, which unlike propane/isobutane, does not vaporize and lingers around potentially waiting to be ignited for a long slow burn. For some discussion on freon alternatives, take a look at an old thread:
http://forums.pelicanparts.com/porsche-911-technical-forum/76715-r12-substitutes-any-one-using-them.html
nhromyak 07-09-2003 09:09 PM
Now I just need to get a vacuum pump...
Thanks for the info.
ipapilot 07-09-2003 09:38 PM
I am sure it has been mentioned in another thread, but in place of a true vacuum pump/old compressor, can one of those systems that hook up to an air compressor work well enough to evacuate a system? I know harbor freight has them for about $20.
Brian
nhromyak 07-10-2003 12:14 AM
I hear those can't pull enough of a vacuum to "boil" out the water.
They might work in a small system "OK". But not in our long-hosed system... :(
I imagine it would be better than nothing.
turbo6bar 07-10-2003 05:17 AM
I do not know the reasoning behind the recommendation, but the makers of Enviro-Safe, competitor to Duracool, do not recommend a deep vacuum of the system. In fact, they say charging into a deep vacuum can result in an overcharge. They claim that moisture in the system does not affect performance or reliability as it would in a system using freon.
As long as the vacuum pump can pull a good vacuum, it doesn't matter how much hose length you have. Long hoses will only mean you have to pump for a longer period of time. It should not affect the degree of vacuum pulled. I have never used the air compressor-style pumps, but I have a feeling you need one monster of a compressor to provide the air.
Jurgen
Jim Sims 07-10-2003 06:26 AM
The hydocarbon mixes probably do not make hydrochloric acid in the presence of water like R-12 does but water in the system will still freeze in the expansion valve and evaporator causing operation and performance problems. The longer one pumps and bakes out the system (car sitting in the hot sun) the better, up to a couple of hours or so. One a side note: at higher vacuums (lower pressures) the length and diameter of the line (it's conductance) one is pumping through affects the ultimate vacuum obtainable at the far end of the line from the pump. This however is not an issue with the vacuum levels required in A/C systems. Overcharging with the hydrocarbon mix replacements probably comes about because it likely most often done without the benefit of pressure gages or a weight scale. Cheers, Jim
turbo6bar 07-10-2003 06:33 AM
Hi, Jim. I think you are correct about the corrosivity of the freon/moisture vs. hydrocarbon/moisture. I do not think moisture is the system is good. It does nothing to help with cooling, as far as I know.
Here is the page that describes the installation procedure.
http://befreetech.com/esinfo.htm
It specifically states that charging under a high vacuum CAN result in an overcharge. I charge by weight, so I really don't understand their statement. I guess the important word to consider is CAN.
Any ideas?
Jurgen
Jim Sims 07-10-2003 06:38 AM
Two seconds after beginning charging one no longer has a high vacuum so I too do not understand their statement. Jim
ipapilot 07-10-2003 08:33 AM
I am not familiar with how exactly to charge a system, but the pumps I referred to earlier utilizing an air compressor claim they are capable of creating a vacuum down to 29.82" I think. As long as you are creating lower than current outside pressure, would you still be succesful in removing any moisture?
Tim Polzin 07-10-2003 08:40 AM
Using the A/C gauges, my two stage compressor with a 3 hp motor will go down to about an indicated 22 in. vacuum, we are at about 1800 ft above sea level.
scottb 07-10-2003 10:12 AM
Tim: Can you describe how you used your compressor and a/c gauges to pull a vacuum? I have a 2 hp Campbell Hausfeld compressor for air tools and the like, and was wondering if I could use it to vacuum my system before recharging. Did you have to make up adapters to attach the compressor intake to the a/c system? I'm really intrigued by this.
Thanks for your help.
Tim Polzin 07-10-2003 10:37 AM
Sure. My compressor is old but pretty big. It uses a standard 3/4 inch pipe thread for the input. I just unscrewed the air filter, fit a reducer from 3/4th to 1/4th, and attached my air hose. The fittings on the A/C gauges seem to connect to a standard 3/8ths (I think, but can't remember) flare fitting which I attach to the air line.
One last thing. Since I use HCs, I disconnected the output line to the tank from the compressor so the air evacuated from the A/C lines did not go into my 100 gal. tank.
Hope that helps.
ipapilot 07-10-2003 11:24 AM
Scott, I am glad you asked that question because it was the next one coming from me!
Another question for Tim, though... With gauges on one side of the AC compressor and your compressor plumbed to the other side, I take it you just shut off your compressor when reaching max vacuum? Also, does the compressor not have any problem with the restricted airflow on the intake side? Seems like it would react adversely somehow... But then again, I've never done any AC work before and am just trying to learn how to make do with tools on hand! So, thanks for the help!
Brian
scottb 07-10-2003 11:45 AM
Brian: My little oilless compressor might start heating up a bit, but I'm guessing it will handle the vacuum just fine.
Scott
nhromyak 07-10-2003 12:25 PM
I just talked to the owner (I think) of DuraCoolusa.com He said, you only need to pull a vacuum if you replaced a component. And you only need 10" of vacuum when you do that.
He went on to say, you only need a static (0 pressure) in the system to install DuraCool. Moisture is not a big concern with DuraCool, as it does not contain Chlorine. I guess when you mix Chlorine with moisture you get a corrosive.
So I ordered a case. It should be here next week. Even though, I only need 2 1/2 cans. Knowing my luck, I won't get it on the first try.
911pcars 07-10-2003 12:29 PM
Environ-Safe's claims look attractive. However, I have some issues (as have others) with their suggestions:
"2 - If desired, pull a vacuum of no more than 10 inches. Unlike freon, Enviro-Safe does not become caustic if moisture is present. Charging under a high vacuum can result in an overcharge. Any overcharge may cause loss of cooling efficiency. "
As Jim pointed out, moisture in the system can cause the expansion valve to freeze and prevent refrigerant from entering the evaporator. The system, under vacuum, will only draw in only as much as you allow from a can. They aren't selling 50 lb. tanks are they?
"3 - Connect gauges and hoses. With compressor off, open cylinder valve or invert can to install Enviro-Safe on low pressure side of compressor (installing as a liquid will not harm the compressor)."
The A/C compressor compresses vapor; it's not a pump (liquid). Typically, only vapor refrigerant installs in the low side. If liquid refrigerant goes into the compressor, it will kill the compressor. It's like filling up an engine cylinder with a liquid (don't try this at home). Maybe they're thinking the system will somehow equalize with the system under vacuum with the compressor OFF (don't think so).
"5 - If a system has been overcharged or has a leak and must be recharged, completely evacuate the system using reclaiming equipment and start the charging procedure over. "
As I mentioned before, no A/C shop is going to "contaminate" their recycling/reclaiming equipment and refrig. tanks with a foreign substance. If it isn't R12 or HFC-134a per their refrigerant identifier, they won't connect to your vehicle. The makers of Enviro-Safe probably realize this and are CTA.
Rejected by their A/C shop, users instead will simply vent the refrigerant to atmosphere. Follow your own conscience (like pouring oil in the gutter). While they claim it isn't a hydroflourocarbon and the release volume probably isn't a whole lot, it is a hydrocarbon.
Sherwood
Jim Sims 07-10-2003 01:01 PM
This is likely how they are getting an overcharge of the system (not too high of vacuum); I bet people are just buying a can tap and cans and adding the mix until they feel they have enough in the system! Without a running system and gages there is no good way to tell if one has a proper charge or not. Sounds like an unfortunate way to get a hose rupture or compressor head failure combined with a flamable gas.
:eek: Jim
scottb 07-10-2003 02:28 PM
Tim: Do you connect the compressor/vaccum to one of the hoses on the a/c manifold set up, and then connect the manifold to one of the schrader valves on the compressor? High side? Low side?
The reason I ask is that I'm wondering how you disconnect the compressor/vacuum without allowing air back into the system.
nhromyak 07-10-2003 07:44 PM
Those are not the directions I am following.
Every direction I have read, whether R134a or R12 and Duracool R12a, tell you to install the can upside down on the low side so it will enter as a liquid.
I don't know why...:confused:
But under 60 PSI (and in the can) this is a gas... correct??? And at higher pressures ~100 - 150 (high side) it is a liquid.. RIGHT?
Then as the liquid goes to gas (via the expansion valve) it goes cold.
SOOO entering this in the low side, from the can it should be a gas. I presume you are turning the can upside down so you get the refrigerant and not the "inert" gas....
:confused:
Anyways... I will see next week.
turbo6bar 07-10-2003 08:20 PM
I recall the first can is charged with the compressor off, so liquid is OK, but then they still tell you to charge the second can with A/C on and the can inverted (charging liquid). I was nervous about doing this, but I have succesfully done this twice.
Wonder if it has anything to do with the fact this stuff is a blend? Different partial pressures of the the gas? Maybe I am too dumb to be thinking about this??? :)
Nick, you've got it backwards, I think: the gas is at higher pressures. When the gas hits the expansion valve, the pressure drops and it turns into a liquid and that change in state removes heat from your car and makes your air nice and cold. :)
The guys at Enviro-Safe and Duracool tell us to do things bass ackwards from things I have been taught on residential A/C systems. I'm just an amateur, though.
jurgen
911pcars 07-10-2003 09:19 PM
I assume you guys have read Chris Bennett's link to:
My contact at Toyota calls these hydrocarbon refrigerants, "rocket fuel". For those of you who think this is no less hazardous then pressurized fuel from the tank to the engine, consider that fuel lines don't run through the car interior like A/C lines tend to do. In addition, fuel is usually in a liquid state, not in a more combustible vapor form like refrigerant inside the evaporator (which sits inside the car). One might consider hydrocarbon-based refrigerants more hazardous to use because of this.
BTW, refrigerant is in a high-pressure liquid form from the compressor to the expansion valve where it vaporizes and absorbs heat in the evaporator. It is in a vapor form all the way back to the low-pressure side of the compressor.
Back to a basic question. What's wrong with using HC134a? It works (though not quite as efficient as R-12); it's readily available, it's safer, the system is serviceable most everywhere you go and it's ... legal.
If your A/C system isn't working due to some design deficiency from the factory, I'd consider updating it (e.g. more efficient compressor, etc.). In addition, one can increase airflow to the condenser, clean fins, evacuate and recharge system w/proper amount of refrig., etc.
You don't want moisture in an A/C system and you cannot drive off moisture using only 10" of vacuum. You need more like 25".
Sherwood
nhromyak 07-10-2003 09:39 PM
Well, I don't know about where you are...
But here in CA - for a shop to do the conversion to R134a (by LAW) they have to replace all the non-barrier hoses. :rolleyes:
BEFORE they replace the hoses, they have to recover the refrigerant $49.99 is the best price I found.
Last I checked, they wanted $500 just to replace hoses... :(
Now they have to replace the drier/accumulator (I have found it as low as $19.99) because it's not R134a compatible.
Vacuum and leak check again $79.99.
NOW the cost of installing the less than efficient R134a... $40 - 50.
Now they can see if the system is running appropriately. If not, they get to vacuum it, fix/replace the evaporator valve (found this for $24.99). ANNDDD again $79.99
So I can do it myself for $80.00 (with R12a) assuming nothing is wrong
Or I can have it done legally for $600+ - assuming nothing is wrong.
:eek:
nostatic 07-10-2003 09:47 PM
why not run something like Freeze12 which I believe is not flammable and is approved for auto use? I believe that's what's going into my system tomorrow when the new compressor/reciever/dryer/expansion valve are installed.
nhromyak 07-10-2003 09:49 PM
Sherwood
I assume you read it too... Specifically #10
[/b]
Is it legal to replace HFC-134a in a motor vehicle with hydrocarbon refrigerants such as DURACOOL 12a® and HC-12a®? [b]
In certain circumstances, the replacement of HFC-134a in a motor vehicle with hydrocarbon refrigerants might be permitted. At a minimum, in order to avoid violating the Clean Air Act, the motor vehicle A/C system must have either been originally designed for use with HFC-134a refrigerant, or must have been previously retrofitted from CFC-12 to HFC-134a refrigerant, AND no sham retrofit must have occurred to convert the system to the hydrocarbon refrigerant. In order to avoid violating other laws, the replacement of the refrigerant must not violate any state or local prohibition on the use of flammable refrigerants in motor vehicle A/C systems.
The following 18 states ban the use of flammable refrigerants such as HC-12a® and DURACOOL 12a® in motor vehicle air conditioning, regardless of the original refrigerant: Arkansas, Arizona, Connecticut, Florida, Idaho, Indiana, Iowa, Kansas, Louisiana, Maryland, North Dakota, Oklahoma, Texas, Utah, Virginia, Wisconsin, Washington, and the District of Columbia.
SmileWavy
I do still agree it can be a deadly mixture. The biggest problem I see is not how flammable it is, but how suffocating it is in an enclosed area...
As I recall, this is heavier than air, and it disperses oxygen. Hence, in a small cabin, such as our car, it can disperse the oxygen if htere is a leak in the evaporator... :eek:
nhromyak 07-10-2003 09:58 PM
I couldn't find it... :(
Where did you find it?
scottb 07-11-2003 01:14 AM
Todd: Are you still getting your a/c charged on Friday? It'll be a nice HOT day. Let's us know the results.
Scott
turbo6bar 07-11-2003 05:58 AM
I feel the hydrocarbon refrigerants are superior to the freon stuff (well maybe not R-12), BUT use of hydrocarbon refrigerants is not a license to take short-cuts. You still need to have the equipment and be prepared to take the time to do the job right. I think part of the problem is guys think this stuff is a quick fix.
Let's do some math. Propane, in gaseous state fills 8.5 cubic feet per pound. For most A/C systems, it takes 12-20 ounces of hydrocarbon refrigerant. So, for lightweight systems, the fill is .75 lbs, and for bigger systems, 1.25 lbs. Let's say you had an accident and the evaporator was damaged and permitted to fill the passenger compartment. The .75 lbs would fill 6.5 cubic feet, and 1.25 lbs would fill 10.625 cubic feet. The Lower Explosive Limit is 1.4% for isobutane and 2.1% for propane, so ignition would require a passenger space of 464 cubic feet for .75 lbs and 758 cubic feet for 1.25 lbs. If my math is right, then it is virtually impossible for a release of propane/isobutane to ignite inside a SEALED passenger compartment.
The drawbacks to hydrocarbon refrigerants: 1) not EPA approved, 2) not in wide use by industry inside USA. I think the reason for the 2 drawbacks is plain and simple, MONEY.
Interestingly, Duracool and Enviro-safe are more expensive than R-134a. Those boobs are shafting the consumer.
just my opinion,
jurgen
ruf-porsche 07-11-2003 07:19 AM
You need to pull a vacuum but you need to maintain that vacuum anywhere from 45 minutes to 2 hours in order to remove all the moisture in the system. Pulling a vacuum for 5 minutes will not remove all the moisture. The longer the system was opened to the air, the longer you must pulled the vacuum.
There has been a previous thread on these conmpressor vacuum machines and everyone who had use it in the past has said they will never do it again
Save your money and go out and rent a vacuum machine.
