Modern Opinions on Shifter Upgrades (G50)
Looking to rebuild the shifter on a G50 whose shift bushings are completely gone.
At first I was going to go full OE Porsche rebuild, but then googling around I found the JWest and Wevo shifters.
I haven't seen any recent threads that discuss the currently available options, I'm curious if there's a consensus on which is best? The car is mostly going to stay stock for the foreseeable future, just want it to feel good to drive
One question I have is whether the JWest or Wevo kits need all of the bushings and other parts that you'd find in, say, this OE rebuild kit https://www.*******.com/products/porsche-manual-trans-shifter-rebuild-kit-genuine-porsche-95042402803kt
Or do those kits replace those parts with aftermarket equivalents meant to work with the different shifter?
Thanks for any thoughts and opinions!
Old 07-08-2025, 07:35 PM
Jwest
Can’t say about wevo, lots of people like. I went with Jwest. He will answer your email questions if you have particular questions that arnt answered in either his many YouTube videos or website. I love mine with the longer shift arm. The spring reverse lockout is not perfect on my car but my shaft might be slightly bent and that might be affecting how perfect I can dial things.
Installation was easy. I spent more time dialing in the collar attachment then the lever. 10x better than stock with short shift kit.
Use the stock plastic bushing or jwests at the rear shaft. The all metal is noisy and harsher and has less forgiveness. Jwest will tell you that, my mechanic told me that
Just do it. Do it. Do it. Do it
Old 07-08-2025, 07:59 PM
tobluforu's Avatar
Do a search, it's getting up just like oil threads.
Old 07-09-2025, 02:44 AM
Arlo911's Avatar
I had a Wevo G50 shifter for about 1 week didn't like it to be honest. Also don't like it on a 915. But that's personal opinion.
Old 07-09-2025, 04:52 AM
faverymi's Avatar
Never like the feeling of short shifters in older 911s.
I end up just rebuilding the original parts.
On race cars I like a gated shifter but that is for another conversation
I like my street cars soft and comfy.... just an opinion
RSA Pinky Helga Turtle
Carrera Luigi CDtdi
Old 07-09-2025, 05:27 AM
FWIW, I have had the JWest in my '87 G-50 for like 10 years. Great product and feel, and relatively easy to install.
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 07-09-2025, 05:54 AM
I'll throw my vote in for wevo. I've never tried the jwest.
Adding the wevo and psj to my '87 was a marked improvement. The g50 shifter is already pretty good, but I'd be lying if it doesn't feel like a bolt action rifle now.
There is some increased noise from the PSJ, but it's minimal.
I have zero regrets in my street car.
Old 07-09-2025, 06:32 AM
Thanks to everyone chiming in!
I'm thinking I might want to restore the stock shifter to like new spec before I decide to put in a whole new shifter. What's not very clear to me is whether or not any of the more expensive new OE shifter parts that I'd have would be getting replaced by aftermarket versions if I do decide to change away from the stock shifter setup? Or is it mostly just the shifter lever itself that's getting replaced?
Generally, from searching, I haven't been able to figure out whether there's a clear preference between certain OE shift mechanism parts and aftermarket versions, and what the tradeoffs between them are? If there was a list of aftermarket parts out there that are unanimously agreed to just be better than the OE versions that would be super helpful to know about.
One example that comes to mind is the shift coupler with the big rubber disk on it. A new OE one is ~$500, and I see a few aftermarket solutions. Other than being cheaper is an aftermarket one (like the JWest plastic one) sacrificing some of the smoothness of the original rubber?
Old 07-09-2025, 08:37 AM
Grappler
Rodsrsr's Avatar
The Wevo made the car fun to drive.
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 07-09-2025, 08:42 AM
Despite what anyone says, there is no real noticeable difference between the OEM or the plastic G50 coupler except for the price.
I rebuilt my G50 shifter and coupler using the JWest kit, and it works fine, albeit there's still a lot of lateral slop while in gear (and that's more because of the 1980's exactingness).
Pick a shifter, install it and try it out. If you don't like it then sell it, and buy a different one. Or you can keep it and have some cool wall art. Pick your own adventure
Old 07-09-2025, 09:34 AM
I'm good with tools.
AG81's Avatar
I've owned a Wevo for the G50. It was fantastic. I have owned a Numeric and a J West for my 915 and the J west is superior in MHO. The Wevo coupler and the Numeric coupler are both great.
WEVO - G50
Numeric - 915
J West 915
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 07-10-2025, 06:58 AM
Porsche Owner
mark4ton's Avatar
WEVO really modernized the feel of my 87. One of the best improvements i've made
1987 Carrera - 2008 Cayenne Turbo
Old 07-10-2025, 07:07 AM
AG81's Avatar
I said the same to everyone about the Wevo in my 88.
02 996 4S
Old 07-10-2025, 07:52 AM
I installed the JWest shifter in my 87 G50 and replaced the shift rod coupler at the same time. Having been used to shifting a modern car with very little throw, the JWest kit made my 911 throw more reasonable and the shifts are solid. I wasn't removing the center console, so I appreciated that it fit back underneath the stock console.
I couldn't be happier with their support. When I ran into an issue trying to access the bolt to release the shift rod from the transmission, JWest not only responded to my inquiry within an hour, but texted me a picture from the shop manual and explained how to move the boot without damaging it. Definitely made a positive impression on me.
1987 Carrera 3.2 coupe
2014 R55 Clubman S
Old 07-10-2025, 10:00 AM
Call 911
dkirk's Avatar
Installed the JWest shifter into my '88 G50 this Spring. I'm totally pleased with it in all respects.
Dave Kirk
My Porsche restoreth my soul.
Old 07-10-2025, 11:22 AM
AG81's Avatar
Got agree with the comments regarding J West. James is extremely helpful.
02 996 4S
Old 07-10-2025, 01:15 PM
Question on the Jwest - If all my bushings and coupler were done recently - can I swap the shifter without messing around with anything else, or is it going to require re-adjusting the coupler?
1986 Carrera 3.2 Coupe in Grand Prix White
IG: @c.cal.porsche
Old 07-10-2025, 01:26 PM
Still here
pmax's Avatar
Great question !
The personal anecdotes are great but lest this ends up just like an oil thread ... let's see if we can help make a little headway towards that discussion. Note this is all random musings on my part, no expertise implied.
Comparing the JWest with OEM, I note the former having a lot more components held together by additional bolts 5,9 which needs to be torqued correctly and set screws 14 which I believe is one more than the previous version. IMO the OEM design wins here on simplicity, the equivalent basically a solid piece. In addition, bolts may loosen and set screws tend to loosen, that may well be the reason for the change in design.
Second, given the OEM lever at the business end is completely vertical as opposed to the angled "attack" for lack of a better word of the Jwest, I suppose the shift action differs.
Old 07-10-2025, 09:01 PM
Still here
pmax's Avatar
Originally Posted by Mtsurfposse View Post
Jwest
Isn't that a 915 in your SC ?
Old 07-10-2025, 09:28 PM
Oh SCHNAPP! I was shopping two years ago and I didn’t pay that much attention to the G50 version. I assume they were mostly the same with a minor change, looking at his webpage it’s a whole new beast. Anyway, JWest makes great stuff with great support
Old 07-10-2025, 10:08 PM
