X-faktory...current builds
2 nice builds going on.
1st: 2.2T to 2.2E/S......Mahle 9.8:1 P&Cs, E-cams, SSIs, Sport muffler, 40IDA carbs....yes ...i said it....carbs. 2nd: 74 2.7 to 2.7RS+....Mahle Motorsports + Nickies, 9.8;1, E-cams, SSIs, Dansk Gt3 sport muffler, RHD EFI/ITBs w/M'squirt controller, etc. ![]() ![]() stay tuned, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Man you stay busy. Good for you.
Ben 89 944,85.5 944 914-6 2.4s GT tribute. 914-6werkshop.com |
The work continues......
While the 2.2t to E/S is being built up....the 2.7 to 2.7RS is getting torn down.......(it is a filthy bugger)
2.2T to 2.2E-ish: Mahle 9.8:1 P&Cs, E-cams, weber 40IDA, SSIs, Sport Muffleretc. 2.7RSish: Mahle +Nickies, E-cams, x-faktory EFI, SSIs, Sport muffler ![]() ![]() regards, al
Uncertifiable!!!
Following with great interest.
What is “X-Factory EFI”? Can you describe how you clean those ugly mag cases? Cheers, Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
Awesome builds.
I recently installed your engine grille and reflector delete in my outlaw build and they look so good!! ![]() ![]() |
i clean the cases old school style........Using solvent(s), toothbrushes. q-tips, wire brushes, Scotch pads, etc......more solvent...rinse & repeat regards, al
sgroer....the build id really looking good!!!
different strokes
While the 2.2 will have Weber 40IDA's...
![]() .the 2.7RS will use these.......x-faktory/RHD EFI ![]()
Fire up!!!
Getting very close to test/tune time for the 2.2T to 2.2E+ engine.......
got it mounted on the test stand.......but ran out of time today...hopefuully tomorrow, I'll fire this one up........... ![]() regards, al
Eng-o-neer
What's involved in going from 2.2T to 2.2E/S (and what actually is E/S...)?
Tremelune,
well, that is just my description, based on the build, compared to 70/71 stock specs. 911T: compression ratio = 8.6:1 911E: compression ratio = 9.0:1 911S: compression ration = 9.8:1 This build......Mahle 9.8:1 P&Cs, E-cams, SSIs, Sport muffler, 40IDA carbs.... so , a little bit of E & S, with E-cams and S compression ratio......
Eng-o-neer
S compression without the super peak of the S cams...Interesting. Anything need to be done to address knock when upping the compression, or did Porsche just detune for marketing purposes?
If I had the choice between an E or S cam I would always choose the S cam .
The myth that the E cam has more TQ is just a myth. Just my experience with engines on the dyno. Ian
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains |
alive!
I'd say it is alive................
nice leak-down
After Testing/tuning of the 2.2E/S, I performed a warm leak-down test.
looking good. 1 thru 6 ![]() ![]() ![]() ![]() ![]() ![]() This engine was built for a local friend....so i get to deliver it and help with the install.... regards, al
3.0 in the house.....
Just received this 3.0 from Ohio. The owner of the engine is an EFI kit customer. and the EFI was successfully installed.... However, per the installer, the engine history was a bit unknown and it had not been run for some time and unfortunately, when he fired up the engine.....it had a bad knock and metal filings in the filter.........from the description, it sounds like a spun rod bearing or???? really won't know until I tear it down. We shall see.......
Home of the Whopper
Really neat stuff Al.
Thanks for sharing!!
1968 912 coupe 1971 911E Targa rustbucket 1972 914 1.7 1987 924S |
Hey Al,
Fun times. Following your 2.7 project with interest. I'm going down a similar path with mine in a few months. Where are you having case machine work done? I may be able to give you a lead down here in P'Town. Cheers, -C
Bone stock 1974 911S Targa. 1972 914/4 Race Car |
type 4 EFI
no 911 content, so sorry....but some of you may be interested in this EFI'd T4 motor
X-faktory Type 4 regards, al
