Dept store Quartermaster
lendaddy's Avatar
Why two gauges on a leak down tester?
Why cant you set the pressure to 100 psi and hook her up? The reading you get is the inverse of the leakdown, no? What am I missing here?
Cornpoppin' Pony Soldier
Old 07-09-2003, 08:46 AM
skinnerd's Avatar
I believe your two gauges are for the following:
gauge 1 - to measure supply pressure
gauge 2 - to measure leakdown pressure
Leakdown is calculated as such:
leakdown% = 100% - [(measured/supplied)*100%]
5% = 100% - [(95/100)*100%]
I think this is how is goes, but others may know better.
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 07-09-2003, 08:55 AM
lendaddy's Avatar
Why not install a valve after the guage and simply close to check supply pressure and open to check leakdown?
Old 07-09-2003, 09:20 AM
skinnerd's Avatar
At first glance, you'd think that would work.
I believe the dual gauge leakdown setup has an orifice such that the supply air is restricted from entering the cylinder (i.e. the supply air is carefully metered into the cylinder). Without this, you'd have to have huge problems to see any leakdown. When the air flow into the cylinder is metered by the small orifice, it is more sensitive (i.e. sees easier) issues such as worn rings or valve seats.
So in a nutshell, you have the supply air that is directly measured with a gauge. The second gauge that measures the "leakdown" is isolated from the supply by a metering orifice. If the air leaks away from the cylinder faster than the metering orifice can keep it at the supply pressure, then you have leakdown to some extent.
Make any sense? This is my understanding of why you need the two gauges and how they work. Again, maybe someone out there knows better.
Doug
Old 07-09-2003, 09:35 AM
Platinum Member
dad911's Avatar
leak down test
Old 07-09-2003, 09:38 AM
