Gear linkage Coupling bushes replacement
Hi all, looking for a little advice - we are rebuilding a 912E and discovered there’s no rubber bushings in the gear linkage coupling. I see the 2 x rubber bushes are sold separately- can anyone explain how these are fitted?
Sigurd 73.5T 3.2SS EFI X87 944S 3.0 |
Full Send Society
Rather than buying the bushings which will suffice but still have play, consider replacing the entire joint with the Wevo version: exponentially better action and precision.
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
The bushings shown are super cheap and easy to replace, as shown. Something like a Wevo PSJ will give you a better shifter feel but also cost a lot more.
'80 SC Targa Avondale, Chicago, IL |
PCA Member since 1988
Corrections: The plastic bushings have no play in them when correctly installed, in fact they are a little tight, which requires them to be pressed in with a vise or big pliers or some such.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Or put the bushings in the freezer and maybe warm up the coupler body, and they slide right in.
They may have "no play" when they're new, but the bushings WILL fail and potentially leave you stranded. IMO, you really should replace the coupler with a modern alternative, like the aforementioned Wevo/Stomski/Tarett unit.
This is what you're looking for:
This. There are much better options for that link.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
gearhead
Aftermarket is superior for this part.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
