1988 911 full batttery charge wont turn over?
Battery fully charged, cab top goes up and down, but wont crank?
DME relay? I dont hear the fuel pump click All fuses look good Ideas welcome Update Headlights dim so I jumped the car battery and she turned over fast as she should be no fire. Usually first bump of starter and she lights Two issues? Under load 5 year old battery on garage queen on tender 11 mos a year toast and a bad DME relay? Ordered UFO Relay
PCA, POC & SCCA long time Member Last edited by 996AE; 08-20-2025 at 02:39 PM.. Reason: update |
Try to jump start it with another car. 12.7 volts is after a fresh charge is meaningless if the amps are not there. I had a battery die, no crank, but a jump start got me home. I took it to the battery store and it tested as bad.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
If the battery has lost a cell or two it will have voltage, and as GH85 says, no amperage to crank. My 996 Turbo just did this. Cranked slow at times fore 2 years, but started, then would not start. Down 1 cell it would crank slowly, it lost a second and would not crank. Charger charged it fine. New battery, problem solved.
Go to an Advanced Auto Parts, Napa, Autozone etc and they can test your battery. My guess, it's down a cell or 2. They will test it for free.
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
Jumped it and it turned over as it should but would not fire. Ill test battery and replace as necessary.
Ordered new DME Relay and no fire when jumped. Odd. Ive had the car for 6 years and this is a first. We will see tomorrow with new battery and new DME Relay.
PCA, POC & SCCA long time Member |
Ordered new DME Relay. Ive had the car for 6 years and this is a first. We will see tomorrow with new battery and new DME Relay.
On one of my cars the DME died. Swapped to a new one (solid state DME with prime function). Car cranked great but not catch. I realize the fuel pump was not priming.....tried to figure out why...the wire in the DME plug that powers the fuel pump came off it's connection some how, in side the plug (maybe when I put the new relay in?). I re-soldered that end together and put an inline blade fuse in the wire right after it leaves the DME plug "just in case."
You might check the power from the DME to the fuel pump. Normally the pump only runs when the engine is cranking or running I believe. Part of why I love the solid state DME, it does a 5 second prime of the pump ever key turn. I can hear my pump run (our not) without the engine. Good luck.
Update 3
New DME, jumped car nothing, battery shows 14.7 volts Wont crank or spin starter
Won’t even spin starter…..hmmm…..starter solenoid? Strange.
Ignition switch is my guess. Lights not coming on with key on, and the door buzzer is intermittent.
Changing the switch is above my pay grade so off to shop Monday. Thanks for the comments.
PCA Member since 1988
If it won't crank when jumped, try several things:
1. Make sure the jumper cables are well-connected. They just have small contact points at the jaws, so be sure those are tight on the battery cable terminals. 2. Clean and put some grease on the battery terminals and ground strap in the frunk, and on the battery cable connection to the starter and the ground strap from the transmission to the body under the car. 3. If the battery is 5 years old, that is about as much as you can expect from a lead-acid or AGM battery. Rather than dicking around with the old battery and jumper cables, buy a new quality battery. If you don't really "need" one now, you will very soon. Just bite that bullet now. Often, replacing the battery will fix "won't start" or "won't crank" problems. If that doesn't fix it, then test the other things people have suggested.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Grounds, grounding ground ground. And clean battery terminals.
Wow I feel silly
After checking grounds, replacing DME, checking for power at starter etc... it was a bad battery It showed full on the charger, tested at 14.7 volts But one of you said it still could be a bad cell or two and when aload is put on it crashes and yep that was it Pulled the battery out and took it in testing. New Interstate group 49 and fired right up Thank you all KISS is where you start I hope this helps someone in the future Thanks again all
I had the same thing with my daily driver. I had a jump start, and it ran and got me back home. I pulled the battery, and took it to Interstate. They used a battery tester. I showed a full charge, but the load test failed in a second. They replaced it with some warranty. The new battery works great.
I have had a battery fail so totally that even a jump would not start my car. I had to remove it in a parking lot, have a buddy take me to the Interstate store, have them test it, and sell me a new battery. The new battery fires the car right up. I carry jumper cables always. And the tools to remove and replace the battery. In the past, batteries just got weaker and gave lots of warning they were dying. Now a battery works fine one minute, and is dead on the next start with zero warning. At least with our 911s, we can do a push start.
