71T bumper to body seal replacement process
Does anyone have a link to a thread that shows the process to change out the bumper-to-body seals on an early 911? It would be the seals just under the tail light lamps that I am looking to replace.
TIA
Old 08-22-2025, 05:03 PM
I'm good with tools.
AG81's Avatar
I've done this a few times and it is quite simple. I do one side at a time.
Just a few nuts and bolts hold it on. Three or four it memory serves me correctly. There is a specific
seal on each side. They are not interchangeable. I use two sided tape to hole it in position while you
refit the corner bumper portion. Not hard at all !!!! You will spend more time cleaning than anything else.
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 08-23-2025, 07:01 AM
PCA Member since 1988
Often, the lip on the bumper the holds the seal will be rusted or even rusted away. Also on the bottom edges of the fenders. Hope that's not the case for you.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 08-23-2025, 12:35 PM
