IDA 3C float level confusion
I know this has been discussed a thousand times but what gauge lines should i be using ?
I had the carbs apart and set the floats to the correct dimensions using a depth gauge and calipers, when i tested with the fluid gauge it was aligning approx. with the lower lines. The consensus seems to be the higher lines for the Webers.
Old 08-26-2025, 09:59 AM
rsscotty's Avatar
Depending on the vial you have, some are different.....
use the lines that are about 35mm above the center of the banjo bolt.
Old 08-26-2025, 10:43 AM
The "top" bottom line is approx. 34mm so I presume it should be set to the lower.
Old 08-26-2025, 11:15 AM
