1985 Carrera
911 3.2 - Ignition cutting when warm. Any tips?
Hi Team,
Second issue with my 911 this year and seems to be another electrical one.
Situation: When cold, car runs well. As it warms jerking starts to appear. Once engine gets to temperature I get heavy jerking above 3k rpm. It feels like the ignition cuts for a split second and it comes back alive with a massive jerk forward. It keeps doing this as the rpm climbs further. Indicated RPM doesn't react to the jerk, they climb like they normally would.
It was late when I got back so I only tested the coil. Comes within range but at the lower spec. I have heard they can still show within range but still be bad and need replacement. Before I buy the part I thought I would reach out and see if anyone has experienced this.
FYI - I replaced the flywheel and ref sensor a few months ago (first issue that left me stranded).
I searched the forum but most engine cutting issues seem intermittent compared to my experience.
Thanks!
Old 08-27-2025, 03:11 AM
Check the simple things first ie; vacuum leaks, also the AFM tracks being worn can also cause the issue you describe, I have also experienced an ECU [Motronics unit] that does exactly as you describe, these are just a few suggestions, I am sure there will be others along shortly with their own.
Ant.
"But instinct is something which transcends Knowledge
We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile"
Nikola Tesla
Old 08-27-2025, 04:15 AM
Also check the CHT as it could be failing open, in which case the engine runs well when cold but mixture becomes too rich once engine is warm.
Gilles
RoW 88 Carrera coupé
Old 08-27-2025, 05:51 AM
Right! Then just jumper the temp sensor with a paper clip when warm.
Dave
Old 08-27-2025, 07:07 AM
Cairo94507's Avatar
When I had an '87 3.2 in my car, I experienced similar issues. Finally, on a trip home from LA (400 miles) the coil died on Hiway 5. Turns out I had the wrong coil with the 3.2. Replaced with proper coil and all was right with the world again. I have never had a coil die before.
'71 914-6 #0372
'17 Macan GTS
Old 08-28-2025, 07:14 AM
I ordered my clutch and flywheel from Patrick MS. They balances the entire assembly as a unit. Great unit, great clutch.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 08-29-2025, 05:37 AM
Schulisco's Avatar
Originally Posted by LBEEMING View Post
Hi Team,
Carry a can of ice spray with you on your next test ride. If car starts jerking again, pull over and cool down the coil, but do not flash freeze it... Does the jerking go away?
The coil may seem to be okay electrically when being cold, but heat can make the difference...if its proved by this test, replace the coil. Not so uncommon on Carreras.
How old are the ignition cables, rotor and distributor cap?
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 08-29-2025, 03:54 PM
1985 Carrera
Thanks everyone for your inputs. Just my luck, the new speed sensor I installed was at fault.
I bought a BMW one, really not sure what went wrong but it's working again fine.
Old 08-29-2025, 11:48 PM
Good news, However; did you make sure you gapped the sensor correctly ? If not, then you may end up with the same issue again.
Ant.
Nikola Tesla
Old 08-30-2025, 12:11 AM
