915 grinding noise
Hi,
I have a grinding noise when downshifting to 4th gear in my freshly rebuilt 915, is this just a matter of adjusting the gear linkage or could it be something else ?
Old 08-29-2025, 12:42 AM
If it’s only happening on the downshift into 4th, it might not just be linkage adjustment. A poorly adjusted coupler or shifter alignment can definitely make gear engagement rough, but a distinct grinding noise usually points more toward synchro wear or something not quite right inside the box. Since your 915 was freshly rebuilt, it could be as simple as the 4th gear synchro not bedding in yet, or it could mean the synchro wasn’t set up correctly.
Old 08-29-2025, 12:48 AM
Thanks a lot
This gearbox has all 5 new synchro’s, new shift sleeve’s for 1-2 and 3-4, new dog teeth on 1, 2 and 3 and perfect dog teeth on 4 and 5.
All shifting forks perfectly adjusted as pr. factory manual. This was checked multiple times over during rebuild.
Old 08-29-2025, 01:03 AM
proporsche's Avatar
It is possible that you are grinding into the reverse when you go from the 5th?..The adjustment to the 5th gear have to be correct.But 1st try to adjust the coupler if you know how.
here is a video
https://www.youtube.com/watch?v=b3nPONBAaZM
Ivan
1985 911 with original 501 587 miles...807 226 km
Old 08-29-2025, 01:56 AM
kevingross's Avatar
Was the installed dimension of the 4th synchro installed on old dog ring measured?
Kevin
Catellus Engineering
catelluseng@gmail.com
http://www.catellusengineering.com
https://www.facebook.com/catelluseng/
Old 08-29-2025, 05:58 AM
proporsche's Avatar
here is the pic..
Old 08-29-2025, 06:16 AM
shoooo32's Avatar
Classic 911 - what type of shifter do you have installed? I agree with Ivan, you're most likely engaging reverse on the downshift.
-Tony
Instagram: @Pablo_the_Porsche | @RuchlosRallye
AchtungKraft #002
Old 08-29-2025, 06:30 AM
915 grinding noise
All synchros measured with micrometer and well within factory spec.
Reverse gear also adjusted as pr. factory spec.
Old 08-29-2025, 06:31 AM
915 grinding noise
Yes, maybe, but the 3-4 gear alignment is quite spot on, also in relation to the 1-2.
This might be the sum of all factors, so I will start fresh and make sure that everything outside the gearbox will be as close to factory spec as possible.
Thanks for all answers so far
Old 08-29-2025, 06:35 AM
proporsche's Avatar
in this case make a video so we can hear it..
Ivan
Old 08-29-2025, 07:12 AM
I agree with proporsche, raking reverse on downshift.
Old 08-29-2025, 07:34 AM
Just a tiny coupler adjustment can fix that. Like one spline.
206 637 4071
Old 08-29-2025, 09:48 AM
If the shift from 3rd to 4th is fine, and it only grinds on the 5th to 4th, it is your reverse lockout not working. The shifter coupler in the back is off.
I tie a bungee cord from the shifter to the steering wheel. Then rotate the shift coupler towards the passenger side, and tighten it up. Try that. It is also important to get the forward and back adjustment correct.
Old 08-29-2025, 01:21 PM
New User
RUf 5 SPD
1988 4Spd 930 with RUF nose cone making it a 5spd box
Crunches first and hard to select gears
Old 08-30-2025, 12:09 AM
