WUR Adventures
Hello All,
Been enjoying my 76 911s w/3.0SC engine. It's been running well in most cases and joy to drive. There is/was one condition where if I gave it full throttle the car would seem to run lean once I backed off with a slight backfire on the exhaust side of the engine. If I came to a stop or pushed in the clutch the car would not idle and die. If I let is sit for 5-10 seconds and then restart the car it would run normally and idle just fine. A couple of months ago I had disassembled the WUR in an effort to understand why the car was running poorly and found what looked like a clogged (partially) inlet mesh on the WUR: ![]() A bit of brake clean and some compressed air had the screen looking much better so I reassembled the WUR. As mentioned the car was running great and it seemed like the full throttle/lean condition was improved. Fast forward to earlier this week and I ran into the full throttle/lean condition issue again and resolved to have another looks at the screen. I purchased an ultrasonic cleaner anticipating removing the screen from the WUR and giving it a good soak. Well that operation did not go according to plan. I'd read you should be able to push out the screen(from the inside) so I inserted a 1.5mm allen and gave it a push only to find the screen still resting in the WUR but now with a 1.5mm hole. Doh! ![]() At that point I gave up and reassembled the WUR (with the damaged screen still in place) hoping to enlist the Pelican brain trust on how to proceed. I seem to remember some folks running the WUR without a screen which is what I'm doing in principal now, but prefer to have some sort of filter for the long run. Prior searches for replacement screens/mesh didn't yield any results. I haven't done a full throttle pull with the "modified" screen to see if the lean condition is resolved yet. Maybe tomorrow. Does anyone have a lead on where to source a WUR mesh screen, or am I best off finding a used WUR with a better screen? Maybe installing an external filter pre WUR? Any suggestions would be appreciated. Cordially, Roger Last edited by ducatiroger; 09-05-2025 at 08:59 PM.. Reason: typo |
Crotchety Old Bastard
It is not unreasonable to assume your entire fuel system is in the same shape as that original screen. Running without a screen is not going to end well. I would flush the entire system and empty and clean the fuel tank. Your fuel distributor is cast iron and rusting from within, only a matter of time before it begins to malfunction. EtOH blended fuels accelerate this action as does allowing the car to sit unused for extended periods.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Sure would like to track down a replacement mesh filter for the WUR. Update: Found mesh filters available at K Jet Specialists in AUS. Cordially, Roger Last edited by ducatiroger; 09-06-2025 at 11:19 AM.. Reason: added detail |
Qualité au top |
