Manual Top Conversion
So I'm finally fed up with the latching motors of the auto top of my '88 Carrera. Three parts of question here:
1. Do I need any other parts than the following? Latch/L 964 565 031 00 x1 Latch/R 964 565 032 00 x1 Sckt screw 6x16 900 067 117 07 x6 Washer 6.4 N 011 524 7 x12 Lock Plate 911 565 707 01 x2 (Is this needed, or is it a targa-only item?) Handle 911 565 075 62 70B x2 Rosetta to cover the left over hole Now these are all obtainable new from Pelican or other places, and come up cheaper than the conversion kit dc auto sales. Any reason to go for the kit, and not just acquire the parts yourself? The said kit runs $1,100 these days. 2. If I only convert the latching mechanism to manual, and keep the raising/lowering mechanism powered, any circuit conversion I need to do to the main motor?For those of you who have/had done this conversion, do you recommend semi, or full manual? I do not mind the weight of the top if going full manual. 3. Is there any concern going full manual in terms of high speed open top driving? I mean if you loosen the main hinge bolt to let the top be free from the main motor, will it cause the top to be insecure against strong wind at >highway speed? Many thanks for your wisdom. Want to free myself from worrying about the power top. |
RETIRED
Talk to dC Automotive he can provide all the parts.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
The manual strikers on the w/s frame are different than power top ones.
RETIRED
Call and ask for Bob Zampardi.
Junk Baron
Gents after way too long they are back in stock, complete kits, rob@dcauto.com
dCAutomotive www.dcauto.com 800-579-2410 dcautomotive@gmail.com www.facebook.com/dcautorecyclers http://stores.ebay.com/dCAutomotive-Porsche-Parts |
Junk Baron
we finally have them again
Manual Conversion Kit……….
Junk Baron
