OsoMoore's Avatar
Safely removing an engine->transmission stud
I'm in the early assembly stages of my rebuild, and I accidentally bent the end of one of the studs that holds the transmission to the engine. I have a new stud, but I'm not sure of the right way to pull the old ones. I'm concerned I will twist the case if I do it wrong, and I don't have any special tools yet.
I'm also unsure if the previous owner used any loctite or similar.
Should I just lock a couple of bolts and see if it comes with a big wrench?
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go!
Old 09-19-2025, 07:50 AM
shoooo32's Avatar
I've never pulled those but I've pulled a bunch of 915 gearbox studs. Two nuts or a cheap stud removal tool and they come right out. Head studs are a different story - I use the fancy Snap-on puller for those.
-Tony
Instagram: @Pablo_the_Porsche | @RuchlosRallye
AchtungKraft #002
Old 09-19-2025, 08:47 AM
OsoMoore's Avatar
The length of this one has me uncertain of what kind of puller/remover is even available.
Old 09-19-2025, 08:52 AM
shoooo32's Avatar
You're not reusing it so you could always grab it with a big vise grip down on the shoulder.
-Tony
AchtungKraft #002
Old 09-19-2025, 10:22 AM
Full Send Society
Weld a cheap wrench to it, heat it and give it hell.
-Julian
1977 911 S: Backdate, EFI/ITB, AC project in the works:
http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html
Old 09-19-2025, 10:25 AM
The 9 Store
Small pipe wrench
All used parts sold as is.
Old 09-19-2025, 10:45 AM
Navin Johnson
TimT's Avatar
Pipe wrench
'69 911 GT-5
'75 914 GT-3
and others
Old 09-19-2025, 11:03 AM
A930Rocket's Avatar
^^^This at the base (and maybe some heat).
Old 09-19-2025, 05:50 PM
The two nut method worked fine with the transmission studs on my 915. I don't recall needing a big wrench. If someone used Loctite, you'll need to heat it up. I use a heat gun to weaken Loctite.
1980 911SC Targa
1990 S2 Cabrio (sold)
2004 C4S (sold)
2006 Boxster (sold)
Old 09-20-2025, 04:16 AM
I remove the left studs to install the engine mount half moon. They just unbolt with double nut.
Bruce
Old 09-20-2025, 09:18 AM
Targa_PB_78_SC
mike sampsel's Avatar
So I'm not the only one who has bent one of these. Double nut worked fine, not that tight. I'm sure vice grips will do as well.
BareRearedRookie
Old 09-22-2025, 04:37 AM
