-   -   Safely removing an engine->transmission stud (http://forums.pelicanparts.com/porsche-911-technical-forum/1183927-safely-removing-engine-transmission-stud.html)
OsoMoore 09-19-2025 07:50 AM
I'm in the early assembly stages of my rebuild, and I accidentally bent the end of one of the studs that holds the transmission to the engine. I have a new stud, but I'm not sure of the right way to pull the old ones. I'm concerned I will twist the case if I do it wrong, and I don't have any special tools yet.
I'm also unsure if the previous owner used any loctite or similar.
Should I just lock a couple of bolts and see if it comes with a big wrench?
http://forums.pelicanparts.com/uploa...1758293448.jpg
shoooo32 09-19-2025 08:47 AM
I've never pulled those but I've pulled a bunch of 915 gearbox studs. Two nuts or a cheap stud removal tool and they come right out. Head studs are a different story - I use the fancy Snap-on puller for those.
OsoMoore 09-19-2025 08:52 AM
The length of this one has me uncertain of what kind of puller/remover is even available.
shoooo32 09-19-2025 10:22 AM
You're not reusing it so you could always grab it with a big vise grip down on the shoulder.
Showdown 09-19-2025 10:25 AM
Weld a cheap wrench to it, heat it and give it hell.
mepstein 09-19-2025 10:45 AM
Small pipe wrench
TimT 09-19-2025 11:03 AM
Pipe wrench
A930Rocket 09-19-2025 05:50 PM
^^^This at the base (and maybe some heat).
montauk 09-20-2025 04:16 AM
The two nut method worked fine with the transmission studs on my 915. I don't recall needing a big wrench. If someone used Loctite, you'll need to heat it up. I use a heat gun to weaken Loctite.
Flat6pac 09-20-2025 09:18 AM
I remove the left studs to install the engine mount half moon. They just unbolt with double nut.
Bruce
mike sampsel 09-22-2025 04:37 AM
So I'm not the only one who has bent one of these. :eek: Double nut worked fine, not that tight. I'm sure vice grips will do as well.
