Safely removing an engine->transmission stud
I'm in the early assembly stages of my rebuild, and I accidentally bent the end of one of the studs that holds the transmission to the engine. I have a new stud, but I'm not sure of the right way to pull the old ones. I'm concerned I will twist the case if I do it wrong, and I don't have any special tools yet.
I'm also unsure if the previous owner used any loctite or similar. Should I just lock a couple of bolts and see if it comes with a big wrench?
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery. |
I've never pulled those but I've pulled a bunch of 915 gearbox studs. Two nuts or a cheap stud removal tool and they come right out. Head studs are a different story - I use the fancy Snap-on puller for those.
-Tony Instagram: @Pablo_the_Porsche | @RuchlosRallye AchtungKraft #002 |
The length of this one has me uncertain of what kind of puller/remover is even available.
You're not reusing it so you could always grab it with a big vise grip down on the shoulder.
Full Send Society
Weld a cheap wrench to it, heat it and give it hell.
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
The 9 Store
Small pipe wrench
All used parts sold as is. |
Navin Johnson
Pipe wrench
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
^^^This at the base (and maybe some heat).
1980 911SC Targa 1990 S2 Cabrio (sold) 2004 C4S (sold) 2006 Boxster (sold) |
I remove the left studs to install the engine mount half moon. They just unbolt with double nut.
Bruce |
Targa_PB_78_SC
So I'm not the only one who has bent one of these.
Double nut worked fine, not that tight. I'm sure vice grips will do as well.
BareRearedRookie |
