1979 911SC smog certification question
Hello all: Im looking at a 1979 911 sc, with 89 K mikes second owner car is on the east coat and apparently its a 48 state smog category car. im in Ca. so i would appreciate any help if you have knowledge I can get this car to pass smog certification here in Ca.?
Thanks T K |
Additionally, There is no smog pump on board but the Cat is there and looks original, Thanks TK
Besides air pump missing, the injection tubes are necessary too for the pump to function accordingly with a belt and the fan pulley unless it was swapped and also there’s an air pump check valve connection to pump and tubing.
So you’ll need to look underneath, often the injection tubing is a bit more difficult to remove and plug the openings, so usually it’s left on the engine. Sourcing the parts might not be difficult but a shop that does these BAR inspections (and re-fittings) would be better to consult and what they look for to get it Passed. Here’s a recent post - maybe that shop is near you for advice…. http://forums.pelicanparts.com/porsche-911-technical-forum/1184468-edge-case-re-importing-ca-car-into-ca-europe.html |
Can a 49-state SC be registered in California? It's not just the air pump, California cars also had EGR. Those parts are going to be much harder to find than the air injection parts.
Maybe you just need the car to be unmodified from the 49-state configuration, and EGR isn't necessary? Mark |
The only time 49 state vs 50 state (or Cal) standards matter is when the car is under a year or two old and you're trying to register it in Cal. They want to be sure that you're not trying to circumvent Cal Smog laws. Obviously a '79 is a tad older than that.
At this point in time it just needs to have the equipment on it that it had from the factory; i.e., if it came with a smog pump and EGR, they need to be on the car and operable. The actual equipment necessary will be on the underhood emissions label. |
I guess a missing just an air pump would be ideal.
Two engines variants for 1979. The Non-CA was 930/04. CA was 930/06. Both came with an air pump and a Cat which are EPA requirements. Not sure what (else) makes a 930/06 California specific. Timing? Higher compression? CIS limits? Tailpipe output numbers more important than certain obsolete parts? Wonder if the emissions shop even check engine numbers on 911’s. FWIW - This is an example of a 79 911 smog test. Probably the visual check list applies to all vehicles. http://forums.pelicanparts.com/uploa...1759872789.jpg |
You only need what came on it and running ok. |
Mark |
Ivan |
