Floor below pedals
I was quoted 3800 to have this sheet metal replaced by a body shop. It sounds high to me or am I wrong?
![]() [img] Last edited by spartan; 10-03-2025 at 08:35 AM.. |
No way I would replace that whole piece for a hole below the pedals. If you buy that piece, just cut out the least amount for the repair. Did that a while ago. Or just fab it from 18ga sheet metal.
Thank you John, I appreciate your response, and I wish I was closer to you.
Post a pic of the rusted floor.
I Strongly agree with John. Patch panels/pieces are often a great way to go. Going this way saved me a lot of money and hassle. A good shop can fabricate even complex patch panels.
I just replaced a section of the rear longitudinal in my engine bay. Restoration Design in Canada provided a salvage rear corner from a donor car (got it just before the tariffs), and shipping was reasonable. They have some good quality used sheet metal as well as new. Would love to hear from others about sources for Porsche salvage sheet metal. The longitudinal & engine support I harvested from the donor left rear corner: ![]() Donor car piece from salvage yard: ![]() Donor pieces installed in my car: ![]()
Dave Project: 1985 Porsche 911 Carrera Coupe 3.2 to 3.4L "Carina" PCA Member- Sacramento Valley region |
Agree with the above, if you only need a hole replaced in the pedal area, a small one, have a patch panel made.
That said there is a lot going on in and around that panel, so replacing it entirely....and properly with spot welding etc.....could easily be $3,800. Also, removing that whole panel could show you other issues that are hiding, so be prepared for some "while you're in there."
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
Banned
That’s way too much, I’ll never pay such amount but that’s just me
