LinkBack | Thread Tools | Rate Thread |
Hi,
First, I am the worst person to work on electricals. so please be patient with my questions. I should stop but my brain does not want to... My low beams on 911SC were not working. I tried replacing fuse (Cheapest fix). Did not work.. So I tinkered with head light switch, looks ok too. Then I rad, the turn signal switch connectors might be the issue. It has 2 copper strips which were separated. I pushed them together, the low beam worked. So, after sometime, the left beam wire going to headlight switch got really hot and melted. I am hoping I dont have to replace the whole wire but the driver side low and high beam does not work at all now. The only thing I can do is order new Turn signal switch which is around $300. I am going to remove the switch today and see if I can see what is up with those 2 copper strips. Does anyone have a working close up picture of 2 strips so I can try to adjust it? I heard those switches are not fixable once gone bad. Any suggestion or critique helps Thanks.
1970 911 T (Sold) 1971 911 T 1980 911 SC 1983 380SL 1983 Rabbit Pickup D |
You will need to replace the melted wire. Try to get the correct color to help others in the future.
For your switch, this thread is very helpful: https://forums.pelicanparts.com/porsche-911-technical-forum/248149-turn-signal-switch-quick-fix-pictures.html All this said, if you are not comfortable working with the car electricals, find a local shop to do it for you. It is easy to make a bad thing worse (as you have already discovered).
I agree.. but each time I ask someone to fix something they ask what car is it.. as soon as I say it is a 911. The price doubles automatically. Hate that.. I bought a relay from JWest hoping that will decrease the load on those small gauge wires and it won't get hot anymore. For now, they only get hot when I pull the headlight switch for low beam.
FWIW, as much as it hurts, sometimes you need a pro to do the right thing.
They are sealed beams from Wagner. Driver side light went out, replaced it with one from NAPA.
Ok. So you should not have an over current problem. The melted wire comes from too high a current. Check your headlight grounds (brown wires).
Headlight switch or at the front inside headlight housing or near the fuse panel? Thanks
Not sure there are any grounds except at the headlight bucket. There may be one off of the headlight relay as well.
Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic Last edited by HarryD; 10-15-2025 at 04:57 PM.. |
Thread Tools | |
Rate This Thread | |
