Clutch Adjustment - Can't get in gear
I am on the final stages of my rebuild and can't get my car into gear. Here is what I have going on.
1973 Porsche 911 Targa body 1976 2.7L Motor 1982 915 Transmission Rennline shifter All are rebuilt and back together. I am trying to get the clutch adjusted before my initial start uo. I followed the steps, giving 1.4mm space between the arm and set screw. I can't seem to get the clutch cable adjusted properly. Maybe too long ? When I press in the clutch, I can't get the car to go into gear. Here is a pic of my set up ![]() Any ideas on adjustments to get the car into gear ?
Jared 73 Porsche 911 Targa 57 Chevy 3100 |
See my thread about my challenges. You need the right pedal box, specifically the arm that the clutch cable attached too. My 75 has the 75 pedal setup, and the 78 transmission I have wont work with that. The omega spring (like yours) setups had a different arm on the clutch pedal shaft to adjust the cable. My clutch pedal goes all the way to the floor and my clutch BARELY disengages. There are pictures in this thread. This might be your issue, or might be contributing to it. I ordered new parts to change my pedal assembly over to the later style and teh parts were under $150 from Porsche.
Clutch Cable Challenges
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
Thanks for sharing. That is helpful to see that I have my omega spring hooked up correctly. I believe my cable is too long. I have adjusted it at the pedal side. It can't go any shorter there.
At the omega spring side when you adjust the two nuts it does not seem to do anything. It's almost all the way tight and still no movement. I am working with a 73 pedal box and an 82 transmission. I don't think that is the issue. Do I have the Omega spring connected correctly ? Any other thoughts of what could be going on ?
Flip the spring on the helper arm over - you don’t want the open ends facing the ground.
thanks for the spring advise on the helper arm. That's an easy fix. That's not the problem I am having. Any thoughts to the bigger problem ?
When installing the trans to the engine...did you verify that the clutch fork was properly mated to the throwout bearing?
regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
That was going to be my question.
"Purists are the Karens of motorsports. IG - Iron_Dad_Moto 1972 Porsche 911 - Long Term Project. 3.6TT/G96.50 1981 Porsche 911SC - In Progress. F/A-18C/D, F-15C, F-35B/C |
Still here
I would think the short arm will be rotating "freely" if not engaged to the TOB whereas the helper spring looks like it is in tension.
as Al said have a look inside the trans. on the bearing and fork like this
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
If the fork isn’t in location and you have closed the bell housing bolts there is a great chance that you could have expanded the fork and need to replace it. The opening on the fork is 75 mm, if crushed it opens up to 79/80 mm making it useless.
Bruce |
Doesn't the 73 pedal box have the wrong clutch shaft for the 82 transmission as Duc Hunter found out in the other thread? You can replace your pedal box shaft or convert your sc transmission shaft to the older style that uses just the original arm and shaft, no omega spring, as I did 37 years ago on my 72. You will also have to use a 72 cable if doing this.
guys, thanks for all the input. I just checked the clutch fork to make sure it's in place. See the picture below. It looks locked in correctly to the clutch. Take a look at the pics.
and here is a pic of my pedal box. I assume it's from a 1973 but lot's of parts were removed from this car.
Jared yes you did but did not put some greese there-not the problem--what is theblack box in front of your gas pedal??it is blocking the view of the cross-shaft
Ivan
here are a few more pics. I have a drive by wire upgraded throttle pedal. It has a 3D printed pedal based for the throttle.
good point anbush67....
looking at you clutch cable it seems you have to make more turns on the nut near the arm.Loose the other nut and take the play away... Ivan the pic you provided does not help to see what cross-shaft you have in your pedal cluster..
guys, thanks for all the input. Duc Hunter has been a big help. based on the fact that I have an 82 transmission and the cable seems to be loose, the cross-shaft on my pedal cluster seems to need to be changed. I have the rounded head shaft and need the more hex shaped end. See the pic below from Duc Hunter's post. I ordered parts last night and will swap this out. Hopefully that allows me to get tension on the cable and adjust the clutch. Stay tuned for an update next week.
I have the rounded shaft on the right. Ordered the one brass one on the left
project update. I changed out the rounded pedal shaft for the squared off version which matches an 82 transmission. The cable is now to long, I am only getting 18mm of travel on the clutch when fully pressed to the floor.
Shortened the cable on the pedal end as short as it can go Adjusted the cable at the transmission as short as I can go. Any ideas on how to adjust the cable ? Do I need to adjust the Omega spring and arm ? I know this issue is adjusting so everything works togethere. Any ideas
