-   -   Help - dashboard/ dash pad install 1980 sc (http://forums.pelicanparts.com/porsche-911-technical-forum/1185109-help-dashboard-dash-pad-install-1980-sc.html)
rwilner 10-18-2025 10:39 AM
My 1980 sc project has no dash pad. I sourced a very nice one but it has no studs or clips to mount it to the sheet metal.
See attached pics of the dash pad…does anyone know the type and locations of the hardware needed to attach this to the body?
I replaced the dash pad in an 84 about 10 years ago and my only recollection is that there should be something here :)
Thanks!!http://forums.pelicanparts.com/uploa...1760809139.jpg
Dpmulvan 10-19-2025 06:19 AM
https://www.rotaloc.com/products/bonding-fasteners
Dpmulvan 10-19-2025 06:33 AM
The plastic ones that go up near the windshield are available here on pelican. They twist into the round holes at the defrost area.
rwilner 10-19-2025 07:10 AM
Thanks…I found a YouTube vid by pelican that shows where the fasteners should go, so I should be good
proporsche 10-20-2025 06:10 AM
looks like you have a dashboard from 1986 and up.It has larger wents.Are you aware you have to cut some metal from the dash away?
Ivan
Dpmulvan 10-20-2025 06:22 AM
Yeh that’s definitely not a 1980 dash
