break fix drive repeat
Help - dashboard/ dash pad install 1980 sc
My 1980 sc project has no dash pad. I sourced a very nice one but it has no studs or clips to mount it to the sheet metal.
See attached pics of the dash pad…does anyone know the type and locations of the hardware needed to attach this to the body? I replaced the dash pad in an 84 about 10 years ago and my only recollection is that there should be something here ![]() Thanks!! ![]() ![]() ![]() ![]()
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
The plastic ones that go up near the windshield are available here on pelican. They twist into the round holes at the defrost area.
Thanks…I found a YouTube vid by pelican that shows where the fasteners should go, so I should be good
looks like you have a dashboard from 1986 and up.It has larger wents.Are you aware you have to cut some metal from the dash away?
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 10-20-2025 at 07:37 AM.. |
Yeh that’s definitely not a 1980 dash
