power window switch reversed, what did I do?
I got my door back together and now the window switch is reversed. Up is down and down is up. is it the blue wire on the window motor? Please help.
Turn the switch 180 or swap the 2 middle wires.
Thank you!!!!
Wildman Emeritus
Once it is dome, take a photo or create a wiring diagram to prevent the same problem in the future when you replace the crappy switch (es) again.
I created a wiring diagram in my Bently manual in the electrical section and it has saved a bunch of time and frustration.
Mike Andrew 1980 SCWDP 2024 Suby Forester 2018 BMW X1- Wife's 2000 Boxter - Sold |
Burnin' Rubber
When I added Always Hot for the windows to operate remote door locks, I made slight extensions for the window switch connectors. Not necessary since I don’t take the door panels off very often but hot diggity dawg it makes dis/reconnecting the switches sooo much easier!
Lash
Plan B if all else fails, see link.
https://forums.pelicanparts.com/porsche-911-technical-forum/288567-power-window-switch-schematic.html
Lash 1963 356 T-6 Normal Coupe 1972 911 T Coupe ..... Sold 1972 911 S Targa ...... Sold 1980 911 SC Coupe Weissach |
