hotdogwater's Avatar
right side torsion bar sticking out
Installing new torsion bars and spring plate bushing but the right side is sticking out. The dvr side when in no issues but this side is pushing the cap out of the spring plate when I tighten up the cover. I hit it with a soft hammer not very hard (space limited) and seemed to go a little more in the inner splines but still sticking out.
Any way to clean/check inner splines? Old bar came out and stuck in the spring plate so I used air hammer to remove it from plate. New bar is same length (maybe 1mm longer) sway-a-way bought from Pelican.
Do I hammer on it harder to set it into inner splines before bolting down spring plate?
-70' 911T -in resto - (runs after 25+ years)
-74' 914/4 - race car - SOLD -
Old 10-13-2025, 02:25 PM
Clean and check the splines on the old one before you start whacking.
Old 10-13-2025, 04:21 PM
PCA Member since 1988
The torsion bars butt up against each other in the middle of the torsion bar tube. If the other bar is in too far, the opposite side won't go all the way in. Check the other side. Take any load off the spring plates and you should be able to lightly tap the bars in so they are even.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 10-14-2025, 01:23 AM
mooch29's Avatar
This is the correct answer. When I did mine I had no idea they meet in the middle. Ended up taking both sides apart and centering the torsion bars and then installing everything simultaneously. Was a bit of a pain, wish I did 1 side at a time to prevent that but live n learn!
'86 Targa - Black
IG: @mooch29
Old 10-14-2025, 07:54 AM
Figured it out, the first side I did, the torsion bar wasn't into the spring plate as far as it should have been. Took it all apart, cleaned the spines again and persuaded it into place and it went together. Thanks for the help!
Old 10-20-2025, 12:45 PM
