-   -   red bushing sway-a-way (http://forums.pelicanparts.com/porsche-911-technical-forum/1185464-red-bushing-sway-way.html)
B61 10-27-2025 10:23 AM
http://forums.pelicanparts.com/uploa...1761585780.png
Hi, installing the sway-a-way rear adjustable spring plate set I bought on PelicanParts I damaged severely one of the large red bushings.
I'm trying to find a replacement bushing, preferably RED but surely of the same material. (Polyurethane?)
Can anybody indicate me where I can find these?
Bruno - Bredene - Belgium
Jeff Alton 10-27-2025 07:50 PM
Did you damage an inner or outer? One side has a larger ID on it than the other on those plates.
It looks like on their website you can order new bushings.
let me check at the shop tomorrow, but I may have a set I don't need. If so, pay the postage and I can send them to you.
Cheers
fallingat120mph 10-28-2025 08:35 AM
Cheers
Just went through this and can verify the ID is different so try and order from the manufacturer or if Mr. Alton has a spare set....even better.
I just wanted to update all my bushings so I ended up using the originals after finding out about the ID difference.
Erik
85RedCarrera 10-28-2025 04:26 PM
I am considering buying the same Sway away spring plates- are you saying that these plates cannot use the stock rubber bushings? If that is true, then I won’t be buying them!
