red bushing sway-a-way
![]() Hi, installing the sway-a-way rear adjustable spring plate set I bought on PelicanParts I damaged severely one of the large red bushings. I'm trying to find a replacement bushing, preferably RED but surely of the same material. (Polyurethane?) Can anybody indicate me where I can find these? Bruno - Bredene - Belgium |
Did you damage an inner or outer? One side has a larger ID on it than the other on those plates.
It looks like on their website you can order new bushings. let me check at the shop tomorrow, but I may have a set I don't need. If so, pay the postage and I can send them to you. Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Just went through this and can verify the ID is different so try and order from the manufacturer or if Mr. Alton has a spare set....even better. I just wanted to update all my bushings so I ended up using the originals after finding out about the ID difference. Erik
1986 911 Coupe 1986 911 Targa |
I am considering buying the same Sway away spring plates- are you saying that these plates cannot use the stock rubber bushings? If that is true, then I won’t be buying them!
Dave Project: 1985 Porsche 911 Carrera Coupe 3.2 to 3.4L "Carina" PCA Member- Sacramento Valley region |
