-   -   Ambient Outside Air Temp Gauge Sensor (http://forums.pelicanparts.com/porsche-911-technical-forum/1185582-ambient-outside-air-temp-gauge-sensor.html)
Koizumi 10-29-2025 01:26 PM
I installed a pretty useless but fun outside air thermometer. I don’t know why I’m obsessed with temps, but I admit that I am.
Anyhow, for those that have such a gizmo in their car, where is the ideal location for the probe?
I stuck mine outside the added-on front oil cooler vent, under the front bumper lip. It seems to be very accurate most of the time but not over 80F. Pretty sure it isn’t getting any direct sunlight.
Excuse the glare… The probe is that itty bitty silver thang under the lip.
https://uploads.tapatalk-cdn.com/202...55d701e838.jpg
https://uploads.tapatalk-cdn.com/202...758c8d4e6b.jpg
https://uploads.tapatalk-cdn.com/202...6a2ba05c41.jpg
Johnr352 10-29-2025 01:38 PM
Nice, where'd you get the little gauge pod?
Koizumi 10-29-2025 01:43 PM
It took forever to find one in Fahrenheit!
https://defender.com/en_us/sea-dog-digital-led-temperature-meter-421618-1
MTN930 10-29-2025 02:23 PM
Nice idea. Been looking for a similar solution.
Interesting why it doesn't work well over 80°. in looking up the link, it reminds me of one we had on our ski boat to measure water temperature - with the temperature sensor mounted flush through the hull.
Can't help but wonder if what you're using is more for lake/sea water temps than air temps which can get way more than 80°.
Koizumi 10-29-2025 02:58 PM
Well, it actually works very well above 80°, I think it’s getting direct sunlight on it at times.
So I was wondering if anyone else has something like my setup but has a better spot to place the probe.
I thought about behind the front oil cooler vent. But it must get hot behind there with the oil cooler right there.
blucille 10-29-2025 03:01 PM
modern cars seem to put those temp sensors in places higher off the ground, so the impact from hot pavement isn't as drastic, and out of the airflow as the car is moving forward. Often behind the front bumper, behind the front spoiler.
On a 911, I would think the front left fender behind the headlight bucket is probably a good spot, or the front valence behind the front bumper.
Koizumi 10-29-2025 03:46 PM
That makes a lot of sense. I’ll try out one of those spots. I wasn’t sure if airflow was good or bad. I guess it’s better sans airflow, sunlight and radiant asphalt heat.
Johnr352 10-30-2025 03:03 AM
Originally Posted by Koizumi (Post 12555571)
Nice! How about the nice looking fitting that holds your two gauges? I like it.
Koizumi 10-30-2025 08:29 AM
Here ya go… It’s the classic Dorman gauge enclosures. There are many variations, 1 gauge, 2 gauge etc… Fits great and is solid. Configure as you see fit: cigarette lighter outlet, gauge, etc.
https://a.co/d/6EOsIQp
MTN930 10-30-2025 08:46 AM
@Koizumi - thanks for the clarification on the temp thing. Must've misinterpreted your original post.
I'll pick one of these up and give it a try.
On the probe, it does seem like most modern cars put it in a place where it's not getting direct sunlight or reflective heat from pavement/roads - behind the bumper somewhere.
Thanks again.
Koizumi 10-30-2025 08:40 PM
Thanks again.
Let us know how it goes!
I’m going to move the probe to the left side behind headlight area.
Now that I’ve had the install for a few weeks (with lots of driving and seasonal weather changes) I can see that it needs to be behind airflow and away from emissive heat sources.
Side note: the gauge is accurate. It just needs to be in the correct place.
evan9eleven 10-31-2025 02:51 AM
Cool little mod!
Anyone know if there is something similar, but that transmits to an app?
GeorgeK 10-31-2025 03:15 AM
http://forums.pelicanparts.com/uploa...1761905621.jpg
Rick Cabell 10-31-2025 05:34 AM
Hi George, did you get that. Custom made?
85RedCarrera 10-31-2025 06:02 AM
They're only $250. Seriously, that is pretty cool. I need a temp gauge in my car to let me know the temp when I'm in freezing conditions. Big problem though- where do I store my cassette tapes then?
https://gaugesvdo.com/products/1415-397-154-vdo-120f-outside-temperature-gauge-kit/?srsltid=AfmBOopM7zRoo0JXzmAtqi18B0Dsiaz6XWJYamgdy PaGoq-OpDZbo722n3M
[URL FIXED]
Rick Cabell 10-31-2025 06:19 AM
Link did not work for me. I assume it has electronic sensor. Cost me $800 to get the old one fixed in my 67 Targa. That was the old original type.
GeorgeK 10-31-2025 08:57 AM
Hi Rick.
NHS did that one for me, about 12 years ago. Still works today
Rick Cabell 10-31-2025 09:00 AM
So is it digital inside? or long probe filled with ether?
Koizumi 10-31-2025 09:30 AM
The VDO unit linked is discontinued, hence the exorbitant price for leftover dead stock. They used to cost $99. You’d think they’d markdown the price instead of asking for more.
In other words, buy now if u want it because they will vanish at some point.
Note that they are standard gauge size 52mm and do NOT fit in the clock space! The clock hole diameter is 80mm!!
GeorgeK 10-31-2025 02:04 PM
Rick, mine is electronic with a wired sensor
