Burnin' Rubber
Koizumi's Avatar
Ambient Outside Air Temp Gauge Sensor
I installed a pretty useless but fun outside air thermometer. I don’t know why I’m obsessed with temps, but I admit that I am.
Anyhow, for those that have such a gizmo in their car, where is the ideal location for the probe?
I stuck mine outside the added-on front oil cooler vent, under the front bumper lip. It seems to be very accurate most of the time but not over 80F. Pretty sure it isn’t getting any direct sunlight.
Excuse the glare… The probe is that itty bitty silver thang under the lip.
Old 10-29-2025, 01:26 PM
Nice, where'd you get the little gauge pod?
____________
'84 911 Targa
Old 10-29-2025, 01:38 PM
Burnin' Rubber
Koizumi's Avatar
It took forever to find one in Fahrenheit!
https://defender.com/en_us/sea-dog-digital-led-temperature-meter-421618-1
Old 10-29-2025, 01:43 PM
Nice idea. Been looking for a similar solution.
Interesting why it doesn't work well over 80°. in looking up the link, it reminds me of one we had on our ski boat to measure water temperature - with the temperature sensor mounted flush through the hull.
Can't help but wonder if what you're using is more for lake/sea water temps than air temps which can get way more than 80°.
Old 10-29-2025, 02:23 PM
Burnin' Rubber
Koizumi's Avatar
Well, it actually works very well above 80°, I think it’s getting direct sunlight on it at times.
So I was wondering if anyone else has something like my setup but has a better spot to place the probe.
I thought about behind the front oil cooler vent. But it must get hot behind there with the oil cooler right there.
Old 10-29-2025, 02:58 PM
Been here a while
modern cars seem to put those temp sensors in places higher off the ground, so the impact from hot pavement isn't as drastic, and out of the airflow as the car is moving forward. Often behind the front bumper, behind the front spoiler.
On a 911, I would think the front left fender behind the headlight bucket is probably a good spot, or the front valence behind the front bumper.
looking for 1972 911t motor XR584, S/N 6121622
Old 10-29-2025, 03:01 PM
Burnin' Rubber
Koizumi's Avatar
That makes a lot of sense. I’ll try out one of those spots. I wasn’t sure if airflow was good or bad. I guess it’s better sans airflow, sunlight and radiant asphalt heat.
Old 10-29-2025, 03:46 PM
Originally Posted by Koizumi View Post
Nice! How about the nice looking fitting that holds your two gauges? I like it.
____________
'84 911 Targa
Old 10-30-2025, 03:03 AM
Burnin' Rubber
Koizumi's Avatar
Here ya go… It’s the classic Dorman gauge enclosures. There are many variations, 1 gauge, 2 gauge etc… Fits great and is solid. Configure as you see fit: cigarette lighter outlet, gauge, etc.
https://a.co/d/6EOsIQp
Old 10-30-2025, 08:29 AM
@Koizumi - thanks for the clarification on the temp thing. Must've misinterpreted your original post.
I'll pick one of these up and give it a try.
On the probe, it does seem like most modern cars put it in a place where it's not getting direct sunlight or reflective heat from pavement/roads - behind the bumper somewhere.
Thanks again.
Old 10-30-2025, 08:46 AM
Burnin' Rubber
Koizumi's Avatar
Thanks again.
Let us know how it goes!
I’m going to move the probe to the left side behind headlight area.
Now that I’ve had the install for a few weeks (with lots of driving and seasonal weather changes) I can see that it needs to be behind airflow and away from emissive heat sources.
Side note: the gauge is accurate. It just needs to be in the correct place.
Old 10-30-2025, 08:40 PM
evan9eleven's Avatar
Cool little mod!
Anyone know if there is something similar, but that transmits to an app?
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 10-31-2025, 02:51 AM
Old 10-31-2025, 03:15 AM
Hi George, did you get that. Custom made?
Old 10-31-2025, 05:34 AM
They're only $250. Seriously, that is pretty cool. I need a temp gauge in my car to let me know the temp when I'm in freezing conditions. Big problem though- where do I store my cassette tapes then?
https://gaugesvdo.com/products/1415-397-154-vdo-120f-outside-temperature-gauge-kit/?srsltid=AfmBOopM7zRoo0JXzmAtqi18B0Dsiaz6XWJYamgdy PaGoq-OpDZbo722n3M
[URL FIXED]
Dave
Project: 1985 Porsche 911 Carrera Coupe 3.2 to 3.4L "Carina"
PCA Member- Sacramento Valley region
Old 10-31-2025, 06:02 AM
Link did not work for me. I assume it has electronic sensor. Cost me $800 to get the old one fixed in my 67 Targa. That was the old original type.
Old 10-31-2025, 06:19 AM
Hi Rick.
NHS did that one for me, about 12 years ago. Still works today
Old 10-31-2025, 08:57 AM
So is it digital inside? or long probe filled with ether?
Old 10-31-2025, 09:00 AM
Burnin' Rubber
Koizumi's Avatar
The VDO unit linked is discontinued, hence the exorbitant price for leftover dead stock. They used to cost $99. You’d think they’d markdown the price instead of asking for more.
In other words, buy now if u want it because they will vanish at some point.
Note that they are standard gauge size 52mm and do NOT fit in the clock space! The clock hole diameter is 80mm!!
Old 10-31-2025, 09:30 AM
Rick, mine is electronic with a wired sensor
Old 10-31-2025, 02:04 PM
