-   -   Replacing engine fuel line rabbit hole. (http://forums.pelicanparts.com/porsche-911-technical-forum/1185809-replacing-engine-fuel-line-rabbit-hole.html)
FrontGarage911 11-04-2025 12:21 PM
While replacing the engine fuel lines without dropping the motor, I want to address everything that sits above the long block. I bought the car 5 years ago with no maintenance history. I have done a valve adjustment right after purchase which was maybe 1,000 miles ago. The car in question 1987 Carrera with 88,800 miles.
Before ordering parts, is there anything that I'm missing "while I'm in there"?
Here's the list:
https://i.imgur.com/o00ur9j.png
https://i.imgur.com/vm3NDfK.png
https://i.imgur.com/UNAyBZ9.png
https://i.imgur.com/vjvlRB8.png
I have the rear man seal just in case I decide to drop the motor. If that does happen, I'll order a clutch kit as well.
Am I missing anything? Help is appreciated.
Current state of the vehicle
https://i.imgur.com/y1HjDHbl.jpeg
https://i.imgur.com/DWRRzHIl.jpeg
https://i.imgur.com/0x2MB1kl.jpeg
https://i.imgur.com/p7w5Z43l.jpeg
Thanks for viewing.
911obgyn 11-04-2025 12:44 PM
All the little vacuum tees and elbows are probably gummy and need replaced, along with throttle plate o ring. I found doing the same on my 85 it helps to have the car on ramps or a lift to save your back from stooping.
FrontGarage911 11-04-2025 12:56 PM
Throttle o-ring is definitely on the list. Great tip on the vacuum lines. I'll see if I can get some new ones in my cart. Thank you.
FrontGarage911 11-06-2025 10:49 AM
A big shout out to our fuel line re-hosing expert Len Cummings! The turn around time was rather impressive. Sending a money order was a non-issue since I was going to the post office to drop off the package anyways. Thank you.
http://forums.pelicanparts.com/uploa...1762454376.JPG
Also, another quick turn around (but not as quick as Len's service). RC Fuel injection gave the injectors a new life. I'm surprised with only 88k miles, the injectors were performing pretty poorly.
http://forums.pelicanparts.com/uploa...1762454448.jpg
http://forums.pelicanparts.com/uploa...1762454517.jpg
Since half of the injectors were dripping, I wonder if i had an issue with one side of the fuel injector rail.
11BC2 11-06-2025 03:37 PM
It’s the California fuel; it has too much ethanol in it, and if you let your car sit for a period of time, the injectors get gummy.
FrontGarage911 11-07-2025 10:34 AM
Are there any additives that we can add to prevent fuel injectors gumming up? I know that's its own topic, but it's something I need to look into. Thanks for the tip.
I drop off a few bits nearby to get plated and just under 48 hours, I get a text at 7am telling me to come in before noon. This is about all the hardware you would find that sits on top of the long block.
http://forums.pelicanparts.com/uploa...1762540397.jpg
http://forums.pelicanparts.com/uploa...1762540427.jpg
Here's a before photo
https://i.imgur.com/wdfTufBl.jpeg
Aztim 11-07-2025 10:46 AM
Wow you're fortunate to have such a plater nearby
Porsche recommended adding techron for cis systems, id run techron or just fill up at chevron a dose of seafoam fron time to time
silverlock 11-07-2025 12:09 PM
In addition to the vacuum lines (some Conti/OE-look from HPS does well), also look at the TB/AFM boot as well. Cracks develop as it ages out.
356Lion 11-07-2025 01:09 PM
Please share how much it cost to have your plating done for those parts.
It could help us determine if our local shops are charging fairly.
I wonder if your guys do mail in and out service.
John
FrontGarage911 11-07-2025 01:31 PM
I really am. Ironically, there are two next door to each other. I drove to the plater shop without using my GPS because I "knew" the area quite well. I mistaken drove past by the place that I was SUPPOSED to go and walked into the neighboring business. I'm not disappointed, but it was eye watering expensive.
See the cost below.
My vacuum lines are not too far off from new condition. I needed a a flat bladed driver to undo the lines to the FPR and damper. TB/AFM boot in fantastic shape without any cracks.
I'll revisit the conditions once I get everything. Great suggestion.
John
I lost my appetite after hearing their quote but I had it done. It was $500. Mind you that I'm in California and It was about 2 miles away from me. California has up the environmental fees.
mike sampsel 11-07-2025 02:21 PM
Be sure to not let your gas sit for more than 6 months (dive it enough to get fresh) add a can of seam foam for every 16 gallons you add. With seaFoam and or stabil fuel freshener they claim two years of freshness, so 6 months should be great.
I can only get ethanol fuel, and following this method I've had no issues. On one of my cars I drain the tank every year and put the old gas in the daily driver, the drain car does not often see enough miles to use up the gas.
PeteKz 11-08-2025 11:24 PM
FYI, "Project Farm" recently finished a long term test of fuel stabilizers. Stabil brand was the clear winner in preventing metal corrosion inside the fuel system. However, none of the tested stabilizers did well at preserving or stabilizing the fuel.
One more time: The best thing you can do to prevent fuel problems is to drive it regularly and put fresh fuel in it. If you know it will be parked for long periods, then try like hell to find pure gas and fill the tank with that. Otherwise, drain the fuel.
FrontGarage911 11-13-2025 10:47 AM
I'll siphon as much as I can to have more control of the fumes. Our garage is attached to our main living area and draining the tank would not be good for the family. But I fully understand your point.
Silly question. How about I fill up with the tank with a few gallons at a time? Would that be more beneficial?
"Drive your car" is so much easier than it sounds!
I would if I could. But for some reason I can find 50 hours to do this fuel line job.
I appreciate the PF suggestion, I'll give that a look. Thank you.
When replacing the air filter a few years ago, I couldn't get the rear bottom air box latch to latch. I tried a bit too hard and well, it broke. Since the whole manifold is out, I've been trying to come up with a way to repair the tab on the air box, and here it is.
I found a washer that matched the size of the crevice, stuck it in a vice and hammered it in to a U shape. I sanded the box and the washer with 80 grit and applied JB Weld. I allowed it to cure over and night and these are the results.
http://forums.pelicanparts.com/uploa...1763059520.jpg
http://forums.pelicanparts.com/uploa...1763059534.jpg
http://forums.pelicanparts.com/uploa...1763059537.jpg
Last one. Can I cut off the end of this cruise control cable to get the bracket replated? Or would it be too short if I were to put a new crimp on it?
http://forums.pelicanparts.com/uploa...1763059645.jpg
FrontGarage911 12-19-2025 11:17 PM
http://forums.pelicanparts.com/uploa...1766214784.jpg
Amazing refurbished fan+housing from FlyingJay.
Mark Salvetti 12-20-2025 05:55 AM
No, I think that would actually be detrimental. The tank "breathes" with temperature changes. You want to minimize the air space in the tank, as the humidity in the air can add moisture to the fuel, especially with the ethanol.
I would use Marine Stabil regularly, and top up the tank before winter storage. You should be fine. Then add fresh fuel in the spring once you get down to about 1/2 tank. If you are really concerned, siphon out half the tank when you take it out of storage, put that in your daily driver, then fill with fresh. But I think that is overkill.
What is FlyingJay's turnaround time for the fan refurb? I want to do that.....
Mark
FrontGarage911 12-20-2025 11:21 PM
Mark
I greatly appreciate the insight. Siphoning isn't a problem as I have become an expert on it upon the car's arrival. It isn't difficult and it's much less work than draining the tank from the bottom and catching it in a pan then transferring to a jug... andwell you get a idea.
FlyingJay's turnaround time was just about 2.5 months. I highly recommend him if you can afford the down time.
ToySnakePMC 12-21-2025 12:34 AM
Nice project to address leaks, or stay ahead of them. And the finished project will be pure eye candy to those of us with this affliction (addiction?) !
Glad to see FlyingJ still turning out beautiful work. He cerakoted and plated my fan assembly a couple of years ago and it still looks perfect. His turn around time can vary, but he returned my finished goods quicker than expected. And Len’s hose & plumbing work is also top notch!
Please keep this thread going so we can see the results. Patrick
