Plug for '79 SC EGR Airbox Hole
When I removed my CIS on my SC without an engine drop, the worst part was getting the EGR valve off, and the intake runner bolt behind it. When I put it back together, I would like to leave the EGR valve in a box for some future poor soul.
The pipe to the exhaust was already capped by a previous owner, and I can easily cap the vacuum intakes on the throttle body. But I'm not sure how to best cap the airbox hole. I'm looking for any bright ideas, or possible sources of a plug that will fit it tightly.
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go! |
ROW '78 911 Targa
PM Tony, he may have one from an old Airbox kicking around to measure for you.
(Boyt911sc)
ROW '78 911 Targa
Or just take the airbox to the hardware store and find a plug.
The 15mm hole is looking fairly difficult to plug cleanly. It is all metal at it's opening. Maybe I can epoxy something across it, and assume that it will be drilled through safely by someone eventually wanting the hole back?
I'm close to just putting the EGR back in, and all the attendant cursing during CIS reinstallation.
Post some pictures......
OsoMoore, Could you post some pictures where you want to cap the air box? Thanks. Tony |
ROW '78 911 Targa
I believe it is the hole under the air flow meter area on the vacuum chamber section of the Airbox in the squared off area around the corner from the CSV. (If that makes sense to you)
Mine has a factory plug there.
I'll see if I can upload one tomorrow. Phone doesn't want to attach pics.
No need for a picture.......
Here is where the EGR hole is located. A threaded plug is not effective because the hole is not threaded, and the hole is metal inset into the plastic of the airbox. I ended up putting back the EGR. It wasn't as bad once I had sleep, time, and lots of careful study.
I still hate the EGR.
EGR connection to the air box.........
It has been a long time since I touched or seen an EGR for 911. How is the metal tube secured to the air box? This could not be simply plugged (?) or it would leak. Do you have a picture of the tube end (fitting if any) from the EGR? I have an EGR some where in my garage and will see what I find out.
Tony |
I'm pretty sure that at the base of that pipe where it connects to the airbox you'll find a threaded fitting with an ID that matches the pipe. (The pipe goes through the fitting.) If you remove that fitting, I think you then find a steel washer and silicone bushing. Tightening the fitting into the airbox compresses the washer and silicone bushing, thus sealing around the pipe.
Couple of suggestions to plug this: - Find a threaded plug with similar threads as the fitting. - Use existing fitting but replace washer with solid disk. - Thread the ID of the fitting and install a plug in it, replace the fitting. |
Back here again and still hate this thing.
I'll try fanaudical's idea about checking the other end of the pipe.
What do you need? It has been 10 years since you posted this problem. Do you need the big plug to seal the air box?
Tony |
So I'm thinking of trying to plug it again. Although I could just put the EGR back in. I suspect I'm getting a little unmetered air around the EGR pipe, but it was running well enough.
I used this plug and it was a perfect fit, found it at a pep Boys
Instagram.com/timofthevalley |
Did you have to cut a thread, or was the metal soft enough to just run it in without doing that?
Im starting to think the airbox on my 76 is different, mine was already threaded
