Suggestions for cleaning inside bell housing?
It’s pretty dirty and greasy. Looks like a lot of oil from triangle of death and oil cooler, oddly nothing from the input snout. I’m thinking just bag the input snout and pressure wash it?
( also resealing the oil seal behind the flywheel wjen I get that resurfaced- likely also some leaking from there)
J 911 SC - 1980 911 S - 1977 |
I have used simple green, a bucket of warm water, and an nylon brush to scrub the inside of bell housings clean. Depending on manufactures, you can get it to about 85% of new. Just depends on how long you want to spend at it
Use simple green HD (it’s at all the home improvement stores), not the green stuff. It’s purple and much safer on aluminum. My understanding is that Regular simple green can corrode aluminum. I use the purple simple green hd since it specifically states it’s safe on aluminum and metals. Make sure to rinse it off afterwards and don’t let it dry on the surface. My transmission and bell housing looks almost new.
HD - hearing you - I'll make sure I grab some... the Simple Green (Green) does trash aluminum.
Thanks! Anything else I should do while in there? Planning on new clutch pack with TOB, etc. Resurface Flywheel New Clutch Fork Main Seal Other?
gearhead
Unless you had a rear mainseal failure or a mainshaft seal failure, most of that should be clutch dust. I'd start with an air compressor.
Then I just use a bucket of dishwashing liquid and water, and a sponge. It's not usually very stuck or attached. Pressure washing seems overkill, imo.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Kevin Catellus Engineering catelluseng@gmail.com http://www.catellusengineering.com https://www.facebook.com/catelluseng/ |
I would go with nitrile gloves, bucket, red scotchbrite pad, dawn
Tru6 Restoration & Design |
For god's sake, don't blow compressed air to it so it goes into your lungs.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
gearhead
I’ve got stage 4 sarcoidosis I wear a mask and glasses for almost everything.
Dawn Power Wash spray foam. Spray, rinse repeat.
Walt 82SC 3.0 81SC 3.6 |
It's one of those things that you'll just have to accept that there's no easy way to clean it back to new, and just deal with it. Cover up the input shaft and T/O bearing sleeve (I had a piece of PVC pipe and a cap that worked ok), then use the garden hose to wet down and get off the big stuff. Then use the Dawn blue stuff and a small wire brush. It'll never come out looking brand new, but it doesn't matter as nobody but you will know.
Dawn Powerwash for the win! Used that, a brush and a plastic scraper. 30 mins later, it’s good!
J 911 SC - 1980 911 S - 1977 Last edited by Guardsred911; 11-15-2025 at 05:02 PM.. |
Visually, the clutch release fork pictured seems fine- however, the vehicle has over 150k and I don’t history on this- are there any ways to check it for integrity, etc, or validate it needs to be replaced?
Registered Minimalist
Visually check the clutch fork for hairline cracks by the shaft and inspect the ends that ride in the TO bearing to see if they are really worn. You can buy a new one, but If I remember they are spendy for what they are.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
