Senior Member
Torsion Bar Sizes
Colleagues, what are the stock torsion bar sizes for an '83 SC, and for an '86 Carrera? Is it 19 and 25 for both? Or did those big lumbering Carreras get stiffer torsion bars that the lighter, more nimble SC's did not need?
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Friend of Warren
Admit it, you have Carrera envy!
Model Year Front Rear 911 1974-77 19mm 23mm 911 1978-85 19mm 24.1mm 911 1986-89 19mm 25mm 911 Turbo 1976-88 19mm 26mm 911 Turbo 1989 19mm 27mm
Kurt V No more Porsches, but a revolving number of motorcycles. |
disband
http://www.pelicanparts.com/techarticles/911_torsion_bars/911_torsion_bars.htm
sup, thats alot of work to upgrade such a minor amount of spring rate between the 78-85 and the 86 on. i was always under the impression that 87 was the 1st g-50 year but possibly thats why the 86 seem to have gotten larger bars?? larger diameter, but shorter in length. the 915 and g-50 cars have different bars, but you knew that. i went to 21/27 combo and love it. not so stiff in around town driving, but very noticeable when pushing it.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
I went with 21F and 28R with Bilstein HD's in F and Sport's in R and I have no complaints. It's a Cab BTW.
Vance '83 SC Cabriolet - The "Matrix" '73 914 - "Spicy Mustard" - SOLD |
83 911 Production Cab #10
Still like your set-up?
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
RETIRED
23/29 and I swapped in Carrera 915 sway bars on my 3.6 powered SC cabriolet. Stiff as my knees after a 40 mile bike ride. Handles like a monorail in the curves. My kids hated the ride, I love it.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Torsion Bar Sizes
Still happy with your 23/29 set up? I was concidering either a 22/29 or 21/28. Confort level for the wife is important.... can't decide
"What the hell is an Aluminum Falcon??" -Palpatine (Robot Chicken) 1978 911SC Targa Working Projects: 1968 912 Last edited by bugstrider; 08-27-2017 at 07:06 PM.. |
I went with 21/27, Bilstein HD, and E.Racing polybronze in a lightweight '75 with 3.2 engine. Can't be beat. Not a track car, just a fast street ride. Wife friendly.
J Mac Current 0 Sold - 67 911T Coupe racecar, 87 911 Cabriolet, 85 911 Targa, 98 Boxster, 95 993 Coupe, 88 911 Cabriolet, 75 911 Carrera #144, modified |
Thanks, that's nice it's still wife friendly and light weight too. I too am using ER PB, Carrera Sways, jury still out on the Bilstein HD or Sport in the fronts with the Sports in the rear. The car is at its full weight of 3046 lbs and a Targa with 16" 7 & 8's. Stance will be set at euro height when complete and since she will be at her full weight, I want a firm flat ride without the worry of skittering about at speed while driving on our wonderful roads here in CA. Sent from my iPad using Tapatalk
"What the hell is an Aluminum Falcon??" -Palpatine (Robot Chicken) 1978 911SC Targa Working Projects: 1968 912 |
Location: behind the redwood curtain, (humboldt county) california
4th power...
Don,t forget that the strength of the "spring" increases to the 4th power of the diameter, so, going from 19 to 21 is a 50 percent increase in stiffness.
I did a 100 percent increase on the green car and it was a bit too much. Flat cornering and great at thunder hill but a bit harsh on rough roads. Chris |
I'm running 23/31 on my G50 car with adjustable monotubes tuned for them. I think that the setup is good, but a tad stiff in the front and can push a bit. I'm actually going 21/31 soon. Rear is good overall.
Formerly known as Syzygy
I think I read somewhere that the Ruf Yellowbird used the factory sized torsion bars but went pretty stiff on the sway bars. Does anyone know if there's some fact to this?
I'm running 22FR and 28RR T-bars on ER rubber bushes with custom valved Bilsteins. The ride's a little bit stiff on anything but smooth roads. However, in fast twisties, even on roughish pavement, it comes into its own, absorbing harsh bumps and remaining stable and planted. I just have to drive her a little bit hard and she comes alive.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
I've had the too stiff car before. I don't think I would even consider the 23 up front.
Derrick |
The most sublime setup I have owned was stock torsion bars up front with Sport Bilsteins, and 26mm torsion bars with HD Bilsteins in the rear.
'17 Cayenne |
Torsion Bar Sizes
Do you think 22's would be too stiff with the rear 29's? In going through my parts locker, I found my new front TB's and they are 22's. Just curious after your statement on the 23's and I was planning on ordering them (29's) tomorrow (Monday). Or changing everything up by going 21/28's. which means selling the 22's. Sent from my iPhone using Tapatalk
"What the hell is an Aluminum Falcon??" -Palpatine (Robot Chicken) 1978 911SC Targa Working Projects: 1968 912 Last edited by bugstrider; 08-27-2017 at 10:03 PM.. |
Torsion Bar Sizes
No. I would try the 22's if I had them. The 21's are firmer, but still feel smooth. The 22's may be getting close to harsh. But I doubt it would be bad. I think the 23's are getting to the point your butt starts bouncing out of the seat at times.
Sent from my iPhone while Driving
Derrick |
Thanks! Nothing like last minute questions.......... I'll give them a go and then pull the trigger on the 29's
Recently took over a 1985 Targa project.
1985 Canadian car. Rears are 27mm, fronts are, presumably stock, 18.8. From research, I presume 27s on the back are not original. The bars are all serviceable. If the bars on the back have been upped from stock, how would one expect this car to handle? Presumably, this set-up would be unbalanced. I got the car with the engine and transmission already removed. The angles measured suggest the car had been lowered by the previous owner. The 27mm bars on the back will suit the type of driving I intend to do, would upgrading the front bars be a recommendation? This is a more of a resurrection than a restoration project, but I don’t want to be left with an ill-handling beast. If upgrading the front bars is a strong recommendation, I’d rather do it now than later Any advice appreciated |
Canadian 3.2 Targa project. Discovered 27mm on the back, presumably upgraded, 18.8, presumably original, on the front. All are serviceable.
What kind of handling would one expect with this set-up. If bigger bars are strongly recommended on the front for driveability, I’d rather do it now. Looking for any advice |
1985 btw
