-   -   Heater control levers or resistor block? (http://forums.pelicanparts.com/porsche-911-technical-forum/1186408-heater-control-levers-resistor-block.html)
PeteKz 11-20-2025 01:45 PM
When I move the top heater control lever to the right, the blower comes on high, then medium, then high again. It should be low, medium, then high. Is this problem the switch on the lever, or the resistor block?
I’m trying to avoid pulling the blower housing out again (lazy).
