OsoMoore's Avatar
Getting My Starter Back Wired (Hot-start Relay Edition)
Engine is almost ready to start up after rebuild, but scratching my head about the starter setup.
New wiring harness has 3 wires:
Big Red, Yellow 15a, Yellow 50
From the car body right nearby:
Big black
From my hotstart relay kit:
Blue connector (gets one of the yellows)
Small Black
Ground
My solenoid has:
Big bolt on left (ground?)
Spade on bottom (horizontal)
Spade on top (vertical)
I'm not sure exactly where they all go. Here's my best guess so far.
Yellow 50 -> Blue receiver
Yellow 15a-> Bottom spade
Small Black -> Top spade
All Three Grounds -> Big bolt
Something doesn't feel right about that - is the red from the engine wiring harness actually positive and should go elsewhere?
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Rebuilt and roaring to go!
Old 11-24-2025, 12:40 PM
The big red coming off the alternator goes to the black wire, which is coming from the battery. They hook on a large terminal.
The solid wire yellow goes to the top tag yellow wire with the blue stripe goes to the bottom tag.
Bruce
Old 11-24-2025, 01:03 PM
OsoMoore's Avatar
All good, thanks Bruce.
Old 11-24-2025, 02:55 PM
