i need measurments of a g50 transaxle...
I need to know how "long" it is. anyone have a semi accurate #?
Insane Dutchman
I am fitting a 6 speed to my '89.....I have a G50/20 lying in my garage.....will it's measurements help you?
In addition to removing the nose piece mounting muffin, I need to remove about 65 mm of its length to fit...figure about 28 mm from the bell housing, 25 mm from using up clearance and move the engine back 10 mm.....eeeeehhhhhaaaaaa! Dennis
1975 911S with Kremer 3.2 1989 911 Carrera Project Car |
yep. From end to end, after shortining it as much as you can, how long is it?
Insane Dutchman
The length that it can be shortened to, excluding the shift rod shaft which would be a bit longer, is 70.8 cm. After trimming the bell housing, it should be 68 cm long.
Dennis
Insane Dutchman
Oh yes, does anyone have a length measurement for a conventional 5 speed G50 (as installed in the 88/89 911 Carrera's?
Thanks in advance... Dennis
Looking for this information also
Thanks, Dave 3 Things To Live By - You can't be Too Rich, Too Thin, or have Too Much Horsepower!
