Using Black w/Silver Inner Heater Hose with Flapper Boxes
Hey all,
I understand from factory Flapper Box to Heat Exchanger hoses were pink/red.. but I have some extra black with silver inner hose that I used to swap some hose elsewhere in the heating system. Other than superiority of the aircraft silicon options and other aftermarket hoses, is there any strict benefits of going that direction? How about disadvantage of using this black hose to replace the* Originals?
1983 911SC - Helibronze Metallic L966 Last edited by cky3396; 12-01-2025 at 08:41 AM.. |
Pelican photo upload not work.
![]() this is 83sc, for what its worth. tia
1983 911SC - Helibronze Metallic L966 |
The engine flexes relative to the body, that is why oe heat exchanger to heat control valve hose is flexible. I suspect the black aluminum hose will have a short life in that application. Rob
I went with the orange Aircraft Spruce as it flexes like all the other options, but is resistant to oil, water, cleans easily, etc. Since anything in the air has a very high manufacturing standard, I have always leaned that way if I can. But I am also a believer in use what's on hand!
J 911 SC - 1980 911 S - 1977 |
thanks for the feedback guys
