-   -   Mating 930 tranny to engine question (http://forums.pelicanparts.com/porsche-911-technical-forum/1186967-mating-930-tranny-engine-question.html)
Yan2947 12-07-2025 01:15 PM
Does anyone have any video on how to mate the 930 tranny to the throwout bearing? I’m a newbie to that and just wanna see a step-by-step or video. It was easy to separate, but I need to put them back together. Just wanna see how the fork gets pushed onto the throwout bearing..
Thank you!
Yan
john walker's workshop 12-07-2025 01:32 PM
Look through the hole on top of the bellhousing as you mate the trans to the engine. Set the bearing with the ears at 6 and 12 o'clock first. Use a mirror and flashlight if the trans is still in the car.
Ryan_Cunningham 12-07-2025 02:06 PM
I don't have a video, but I recall it being very finicky. Like John said, a flashlight and mirror helps.
Yan2947 12-07-2025 03:00 PM
Thank you so much. Tranny is out of the car so it should be easier. So start at six and 12 o’clock and push the fork onto it. Do I then turn it to three and 9 o’clock?
Yan
john walker's workshop 12-07-2025 05:41 PM
No, the fork locks the bearing in place once it's behind it.
A930Rocket 12-07-2025 05:44 PM
Mating the transmission to the engine, seems to be one of those tasks, that either goes on correctly, the 1st time or the 50th time.
As you pull the two together, the clutch fork will pivot into the correct position.
As mentioned, you can look in through one of the bellhousing gaps, to make sure it’s installed properly
Yan2947 12-07-2025 06:11 PM
Thanks, John and Ryan and A930rocket. I think I understand and I appreciate it.
Yan
Yan2947 12-19-2025 07:09 AM
Does this look like the fork is correctly attached to the throwout bearing?
http://forums.pelicanparts.com/uploa...1766156902.jpg
john walker's workshop 12-19-2025 07:26 AM
Appears to be.
Ryan_Cunningham 12-19-2025 08:10 AM
Looks correct.
Yan2947 12-19-2025 09:08 AM
OK, thank you for all the help. Really appreciate it.
